Page 1 of 3 1 2 3
To Clutch fan or Not to Clutch fan #2865152
12/27/20 09:09 AM
12/27/20 09:09 AM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
Before I scour the internet I thought I'd ask here first. Building a mild to factory 67 440 4-speed GTX and was thinking of using a 7-blade clutch fan vs a solid 7-blade fan. I think factory it would have had the clutch fan? but, what are the benefits of a clutch fan over a solid? or are there any really?
Thanks info all.
RS23L7 4-Speed
Re: To Clutch fan or Not to Clutch fan [Re: Mopar_Mike] #2865157
12/27/20 09:20 AM
12/27/20 09:20 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
Hi Mike,
Gotta be a clutch fan every Time!
Solid fans are noisy and rob horsepower...
Most folks are going Ali rad and electric fans these days... penguin
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: To Clutch fan or Not to Clutch fan [Re: Mopar_Mike] #2865171
12/27/20 10:31 AM
12/27/20 10:31 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Why not take a little more load off the engine with the clutch? There is no down side to it other than the initial cost.
Master, again and still
Re: To Clutch fan or Not to Clutch fan [Re: Mopar_Mike] #2865178
12/27/20 10:45 AM
12/27/20 10:45 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Clutch. twocents
Re: To Clutch fan or Not to Clutch fan [Re: justinp61] #2865189
12/27/20 11:08 AM
12/27/20 11:08 AM
Danville, NH
Danville, NH
Clutch it is! Thanks everyone.
RS23L7 4-Speed
Re: To Clutch fan or Not to Clutch fan [Re: Mopar_Mike] #2865190
12/27/20 11:11 AM
12/27/20 11:11 AM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
If using mechanical fan then yes clutch is best , and more importantly a proper shroud
Re: To Clutch fan or Not to Clutch fan [Re: DaveRS23] #2865266
12/27/20 02:16 PM
12/27/20 02:16 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I DISAGREE!!! I love the sound of a noisy flex fan, that noise can also serve as a shift point indicator LOL
just stirthepota bit. LOL grin
CLUTCH all the way
Re: To Clutch fan or Not to Clutch fan [Re: TJP] #2865348
12/27/20 05:17 PM
12/27/20 05:17 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
At least in a B-body there's room for a fan clutch! scope
It's so tight on my 451 Dart that even the short Hayden 2947(?) doesn't fit.
So I went to Contour fans and a PWM controller. No problem stirthepot
Re: To Clutch fan or Not to Clutch fan [Re: DrCharles] #2865349
12/27/20 05:23 PM
12/27/20 05:23 PM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
Recently someone was telling me there are two different kinds of fan clutch’s? The kind you get from Hayden and the one you get from Tonys mopar parts? I forget what that person called each but they said they behaved completely differently. The one from Tonys will cool better. Anyone have an insight into what the differences were again? If any? Thanks guys.
Ive got the heavy duty short hayden version on my 67 GTX. It cooled better then the fixed fan. My vote is for the fan clutch.
Re: To Clutch fan or Not to Clutch fan [Re: Suregrip391] #2865356
12/27/20 05:38 PM
12/27/20 05:38 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
There are thermostatic clutch fans that are temperature controlled and there are rpm controlled fans that limit fan speed.
https://www.rockauto.com/genImages/577/GPD%20Fan%20Clutch%20Types.pdf
Re: To Clutch fan or Not to Clutch fan [Re: Sniper] #2865363
12/27/20 05:48 PM
12/27/20 05:48 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
^^^ Yup. Temp-controlled (engage at higher temps) typically have a coiled flat spring on them.
RPM-controlled typically don't have that spring, they're like the opposite of a torque converter.
Re: To Clutch fan or Not to Clutch fan [Re: Mopar_Mike] #2865408
12/27/20 07:36 PM
12/27/20 07:36 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I run thermal clutches on all my stuff and always have. When cold, they are very loose and then when the hotter air hits the spring, they get tighter. Non thermals are just the same amount of friction all the time. I also replace them every 3 or 4 years as they tend to loosen up with use. Especially on the Hemis that turn more Rs than the wedges. And because I run a cut down truck fan with big blades, I run a heavy duty or severe duty clutch.
Here are a couple of links that explain the difference better.
www.haydenauto.com/en/technicians-resources/faq-fan-clutches
https://itstillruns.com/difference-thermal-vs-nonthermal-fan-clutches-12246205.html
Re: To Clutch fan or Not to Clutch fan [Re: DaveRS23] #2865453
12/27/20 09:12 PM
12/27/20 09:12 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Damn it, now I'm feeling like I need to get one for my Power Wagon. I was fine without before this thread.
Facts are stubborn things.
Re: To Clutch fan or Not to Clutch fan [Re: larrymopar360] #2865459
12/27/20 09:34 PM
12/27/20 09:34 PM
Detroit, Mi
michiganhotrod1 Offline
Detroit, Mi
The old Mopar Performance manuals quoted an approximate 10 HP gain at higher RPM's for theclutch fan.
Pay attention to hood and cowl seals for cooling performance, BTW.
Mark
Re: To Clutch fan or Not to Clutch fan [Re: Mopar_Mike] #2865561
12/28/20 05:29 AM
12/28/20 05:29 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
This graph show the viscous clutch on the original Mopar 340 V8
Re: To Clutch fan or Not to Clutch fan [Re: Mopar_Mike] #2865562
12/28/20 05:49 AM
12/28/20 05:49 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
FFS's electric.Try ZERO horsepower loss. What is wrong with you people? shake_head
Throw 8 pounds of dead weight and 5 less hp in the scrap metal pile where it belongs: electric fans have been doing the job since the 80's.
Mo' Farts
Moderated by "tbagger".
Re: To Clutch fan or Not to Clutch fan [Re: Grizzly] #2865579
12/28/20 08:26 AM
12/28/20 08:26 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Except for the HP to run the alternator to run the fan, no free rides out there.
Re: To Clutch fan or Not to Clutch fan [Re: 360view] #2865582
12/28/20 08:29 AM
12/28/20 08:29 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Doubtful, the 340 isn't a 5.7L. More likely it's a SBC.
Re: To Clutch fan or Not to Clutch fan [Re: Sniper] #2865586
12/28/20 08:43 AM
12/28/20 08:43 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
I dont worry about any wind noise from the fan. I run a 7 blade Chrysler steel fan no clutch with a clean good running rad with stroud and a 160 high flow state and mated water pump and housing. The hemi runs at 163 Deg. in any heat. If you are going to run the clutch on the fan buy new. .
1971 HEMI E BODY REGISTRY
Re: To Clutch fan or Not to Clutch fan [Re: hemicar1971] #2865587
12/28/20 08:56 AM
12/28/20 08:56 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I had a non-clutch seven blade fan on one of my '62's for a while. It was VERY noisy! At 50mph it sounded like a hurricane under the hood.
Page 1 of 3 1 2 3
