To Clutch fan or Not to Clutch fan
#2865152
12/27/20 09:09 AM
12/27/20 09:09 AM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
Before I scour the internet I thought I'd ask here first. Building a mild to factory 67 440 4-speed GTX and was thinking of using a 7-blade clutch fan vs a solid 7-blade fan. I think factory it would have had the clutch fan? but, what are the benefits of a clutch fan over a solid? or are there any really? Thanks info all.
RS23L7 4-Speed
Re: To Clutch fan or Not to Clutch fan
[Re: Mopar_Mike]
#2865157
12/27/20 09:20 AM
12/27/20 09:20 AM
Posts: 348 Isle of Sheeps
Gtxxjon
Isle of Sheeps
Hi Mike, Gotta be a clutch fan every Time! Solid fans are noisy and rob horsepower... Most folks are going Ali rad and electric fans these days...
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
[Re: Mopar_Mike]
#2865171
12/27/20 10:31 AM
12/27/20 10:31 AM
Posts: 12,265 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Why not take a little more load off the engine with the clutch? There is no down side to it other than the initial cost.
Master, again and still
[Re: Mopar_Mike]
#2865190
12/27/20 11:11 AM
12/27/20 11:11 AM
Posts: 630 Ct
Wirenut
Ct
Clutch it is! Thanks everyone. If using mechanical fan then yes clutch is best , and more importantly a proper shroud
[Re: DaveRS23]
#2865266
12/27/20 02:16 PM
12/27/20 02:16 PM
Posts: 15,503 Omaha Ne
TJP
Omaha Ne
Why not take a little more load off the engine with the clutch? There is no down side to it other than the initial cost. I DISAGREE!!! I love the sound of a noisy flex fan, that noise can also serve as a shift point indicator LOL just a bit. LOL CLUTCH all the way
[Re: DrCharles]
#2865349
12/27/20 05:23 PM
12/27/20 05:23 PM
Posts: 1,978 USA
Suregrip391
USA
Recently someone was telling me there are two different kinds of fan clutch’s? The kind you get from Hayden and the one you get from Tonys mopar parts? I forget what that person called each but they said they behaved completely differently. The one from Tonys will cool better. Anyone have an insight into what the differences were again? If any? Thanks guys.
Ive got the heavy duty short hayden version on my 67 GTX. It cooled better then the fixed fan. My vote is for the fan clutch.
[Re: DaveRS23]
#2865453
12/27/20 09:12 PM
12/27/20 09:12 PM
Posts: 15,938 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Damn it, now I'm feeling like I need to get one for my Power Wagon. I was fine without before this thread.
Facts are stubborn things.
[Re: Mopar_Mike]
#2865562
12/28/20 05:49 AM
12/28/20 05:49 AM
Posts: 6,017 Salem
Grizzly
Moparts Proctologist
Salem
FFS's electric.Try ZERO horsepower loss. What is wrong with you people? Throw 8 pounds of dead weight and 5 less hp in the scrap metal pile where it belongs: electric fans have been doing the job since the 80's.
Mo' Farts
Moderated by "tbagger".
[Re: 360view]
#2865582
12/28/20 08:29 AM
12/28/20 08:29 AM
Posts: 6,322 nowhere
Sniper
nowhere
This graph show the viscous clutch on the original Mopar 340 V8 Doubtful, the 340 isn't a 5.7L. More likely it's a SBC.
[Re: Sniper]
#2865586
12/28/20 08:43 AM
12/28/20 08:43 AM
Posts: 5,122 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
I dont worry about any wind noise from the fan. I run a 7 blade Chrysler steel fan no clutch with a clean good running rad with stroud and a 160 high flow state and mated water pump and housing. The hemi runs at 163 Deg. in any heat. If you are going to run the clutch on the fan buy new. .
1971 HEMI E BODY REGISTRY
