Page 3 of 5 1 2 3 4 5
Re: Big block swap [Re: ] #2864756
12/25/20 08:43 PM
12/25/20 08:43 PM
WV
Danny Offline
Danny  Offline
WV
RWG i was going to ask if it was a 400 block used in the build, but i see where you specified 440, I read the low deck blocks clearance is better
Re: Big block swap [Re: 440_Offroader] #2864764
12/25/20 09:07 PM
12/25/20 09:07 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Maybe find a donor truck?
That is what I did way back when. I found a '77 400 truck that had been wrecked. Never did understand what exactly happened. Truck still ran and drove surprisingly good despite the damage to the bumper and grill. The weird thing was on the side of the impact, the side of the block was broke off too. When I pulled the mount out, it still had a chunk of block attached to it. You could see the cylinder wall...... eek But it ran beautifully. confused shruggy
I stripped the truck of everything I needed and then some, and sold hat was left to a co-worker that made a trailer out of the back half . Probably the only time I came out ahead on parts.
Before I found this wrecked one for parts, I can't tell you how many 440 trucks I found with a 2bbl on it............. (they weren't 440's) rolleyes shake_head
John
Re: Big block swap [Re: larrymopar360] #2864826
12/26/20 08:53 AM
12/26/20 08:53 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
I went the donor truck route but didn't take the booster. I swapped out the booster and master for an older model reman on my '80.
Re: Big block swap [Re: redraptor] #2864851
12/26/20 11:13 AM
12/26/20 11:13 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Do those stock manifolds flow ok or get to hot?
Re: Big block swap [Re: cudaman1969] #2864883
12/26/20 01:03 PM
12/26/20 01:03 PM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
Couple of things I prefer: I would prefer running some type of headers. I have hedman ultra flows right now on my 360 (obviously won't transfer over to big block. I don't want to lift the truck past stock for any clearance. Just not my preference in looks. I have 33's on it now and that's the biggest tire I would want also. I don't think I'll ever find a donor big block truck in this area, and I really like the idea of a crate engine. Already built, as I'm not able to build it myself. Possibly something with aluminum heads (I know costly but helps with weight reduction for adding a big block. Even just the aluminum intake will make up some). A donor truck would be great for all the peripheral parts, I get that, but finding, storing, and tearing apart is problem. I don't have the facilities for that either. I'm going to take a look in my city though, and if there's one right here, probably can't turn that down. I'll pay my buddy to store, etc.
If I stayed with small block, I'd even prefer sell the current factory 360-4 for a built 360/408. Less down time and choosing of parts, etc.
Facts are stubborn things.
Re: Big block swap [Re: larrymopar360] #2865049
12/26/20 08:39 PM
12/26/20 08:39 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I have this guy 15 minutes from me, good feedback, that I could consider https://www.ebay.com/itm/MOPAR-440-...et-strip-540hp-ready-2-run/333610445321?
Also, Brevard Cylinder Head (Vic), which I know a lot of you are familiar with.
Re: Big block swap [Re: larrymopar360] #2865097
12/26/20 10:39 PM
12/26/20 10:39 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Thats fine now prepare for the other 10k to finish the job unless you can do it all your self.
Re: Big block swap [Re: cudaman1969] #2865124
12/27/20 01:20 AM
12/27/20 01:20 AM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Originally Posted by cudaman1969
Originally Posted by poorboy
I can tell you from experience that a big block center sump car oil pan doesn't work well with a 4x4. I put a 70 400 into a 70s 1/2 ton that had a dis functioning 4x4 setup, but retained the front axle (a broke teenager that needed a truck, bought the 4x4 without a drive train and had a 400 & 727 sitting). After the install, I slid into a ditch in a snow storm, the front axle smashed the oil pan and bent the pickup tube. Gene
So it will fit on a two wheel drive? Just eyeballing I thought it would even if notching the frame. A hammer and dolly can fix a valve cover too. 440 with six-pac ac unleaded heads and regular gas here I come.
I couldn't tell you for sure, the one I threw together was a 4x4 chassis.
The one real 440 2 wd truck I had had the truck oil pan on it, leaking dipstick tube and all. It been a long time ago, but I doubt you could have pulled that truck pan off the motor without raising the motor. I think the car pan's sump would be pretty close to the same place the 2wd cross member is. Gene
Re: Big block swap [Re: cudaman1969] #2865143
12/27/20 07:29 AM
12/27/20 07:29 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
I thought they were ok, but, no one here likes stock manifolds. tsk
Re: Big block swap [Re: poorboy] #2865180
12/27/20 10:50 AM
12/27/20 10:50 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Thanks, I’ll pull the front end off to get a good look on how it all fits. Then make up a set of shorty headers too.
Re: Big block swap [Re: NITROUSN] #2865215
12/27/20 12:24 PM
12/27/20 12:24 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
No I can't do it all myself. I'm aware all the costs associated when doing a swap, and I know it gets heavy. I've done several crate engine/trans swaps. That's why I'm asking, and considering staying small block. I've swapped crate 360/727 into several 318/A999 cars and all kinds of unexpected come up, I know. Mounts, linkages, driveshaft length, brackets, and on and on.
Thanks.
Re: Big block swap [Re: Guitar Jones] #2865876
12/28/20 09:19 PM
12/28/20 09:19 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Originally Posted by Guitar Jones
Why not just stroke the 360?
Has anyone got a 100k miles out of a stroker small block? I have read about stokers with 40k miles needing a rering already. 100k plus reliability is why I am going with a big block.
Re: Big block swap [Re: mgoblue9798] #2866065
12/29/20 02:39 PM
12/29/20 02:39 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I only have about 8k on mine, so I'll be interested in the responses on this. Never heard of issues like this on strokers.
Re: Big block swap [Re: larrymopar360] #2866276
12/30/20 12:11 AM
12/30/20 12:11 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Shorty pistons are gonna have a lot of rock in that short bore. The reason 3.58 was the most Chrysler could push it and live a long life.
Re: Big block swap [Re: cudaman1969] #2866709
12/30/20 08:40 PM
12/30/20 08:40 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Couple that with the increased side loading from the longer stroke.
Re: Big block swap [Re: larrymopar360] #2866793
12/30/20 11:52 PM
12/30/20 11:52 PM
montana
BANDIT Offline
BANDIT  Offline
montana
A few years ago, I sold all of the big block hardware off of a 77 w-100 I picked up, when I talked to the guy a little while back, he still had the stuff. PM me for his number Jim.
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: Big block swap [Re: mgoblue9798] #2867234
12/31/20 11:10 PM
12/31/20 11:10 PM
Guitar Jones Offline
None of those things are really an issue. The taller deck of the Mopar is still better than the chevy. I think the problem is the things run so well they get hammered on a lot. The blocks are not that great so things move around a bit especially at 7000 RPM and that is where the problems come in. If you were to build a lower RPM torque engine for a truck the reliability and longevity shouldn't be an issue.
Re: Big block swap [Re: Guitar Jones] #2867416
01/01/21 11:36 AM
01/01/21 11:36 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Totally respectfully disagree.
Re: Big block swap [Re: cudaman1969] #2867433
01/01/21 12:10 PM
01/01/21 12:10 PM
West Virginia
B1Frank Offline
B1Frank  Offline
West Virginia
I used factory parts, mine is a 72 413 with a complete rebuild , no exhaust manifolds #452 unleaded heads.
Re: Big block swap [Re: B1Frank] #2867509
01/01/21 01:34 PM
01/01/21 01:34 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Just did some more measuring, gotta use the truck pan, or make one, no way around it.
