Re: Big block swap
[Re: cudaman1969]
#2864883
12/26/20 01:03 PM
12/26/20 01:03 PM
Posts: 15,874 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Couple of things I prefer: I would prefer running some type of headers. I have hedman ultra flows right now on my 360 (obviously won't transfer over to big block. I don't want to lift the truck past stock for any clearance. Just not my preference in looks. I have 33's on it now and that's the biggest tire I would want also. I don't think I'll ever find a donor big block truck in this area, and I really like the idea of a crate engine. Already built, as I'm not able to build it myself. Possibly something with aluminum heads (I know costly but helps with weight reduction for adding a big block. Even just the aluminum intake will make up some). A donor truck would be great for all the peripheral parts, I get that, but finding, storing, and tearing apart is problem. I don't have the facilities for that either. I'm going to take a look in my city though, and if there's one right here, probably can't turn that down. I'll pay my buddy to store, etc.
If I stayed with small block, I'd even prefer sell the current factory 360-4 for a built 360/408. Less down time and choosing of parts, etc.
Facts are stubborn things.
Re: Big block swap
[Re: cudaman1969]
#2865124
12/27/20 01:20 AM
12/27/20 01:20 AM
Posts: 10,563 Freeport IL USA
poorboy
Freeport IL USA
I can tell you from experience that a big block center sump car oil pan doesn't work well with a 4x4. I put a 70 400 into a 70s 1/2 ton that had a dis functioning 4x4 setup, but retained the front axle (a broke teenager that needed a truck, bought the 4x4 without a drive train and had a 400 & 727 sitting). After the install, I slid into a ditch in a snow storm, the front axle smashed the oil pan and bent the pickup tube. Gene So it will fit on a two wheel drive? Just eyeballing I thought it would even if notching the frame. A hammer and dolly can fix a valve cover too. 440 with six-pac ac unleaded heads and regular gas here I come. I couldn't tell you for sure, the one I threw together was a 4x4 chassis. The one real 440 2 wd truck I had had the truck oil pan on it, leaking dipstick tube and all. It been a long time ago, but I doubt you could have pulled that truck pan off the motor without raising the motor. I think the car pan's sump would be pretty close to the same place the 2wd cross member is. Gene
Re: Big block swap
[Re: poorboy]
#2865180
12/27/20 10:50 AM
12/27/20 10:50 AM
Posts: 8,270 fredericksburg,va
cudaman1969
fredericksburg,va
I can tell you from experience that a big block center sump car oil pan doesn't work well with a 4x4. I put a 70 400 into a 70s 1/2 ton that had a dis functioning 4x4 setup, but retained the front axle (a broke teenager that needed a truck, bought the 4x4 without a drive train and had a 400 & 727 sitting). After the install, I slid into a ditch in a snow storm, the front axle smashed the oil pan and bent the pickup tube. Gene So it will fit on a two wheel drive? Just eyeballing I thought it would even if notching the frame. A hammer and dolly can fix a valve cover too. 440 with six-pac ac unleaded heads and regular gas here I come. I couldn't tell you for sure, the one I threw together was a 4x4 chassis. The one real 440 2 wd truck I had had the truck oil pan on it, leaking dipstick tube and all. It been a long time ago, but I doubt you could have pulled that truck pan off the motor without raising the motor. I think the car pan's sump would be pretty close to the same place the 2wd cross member is. Gene Thanks, I’ll pull the front end off to get a good look on how it all fits. Then make up a set of shorty headers too.
Re: Big block swap
[Re: NITROUSN]
#2865215
12/27/20 12:24 PM
12/27/20 12:24 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Thats fine now prepare for the other 10k to finish the job unless you can do it all your self. No I can't do it all myself. I'm aware all the costs associated when doing a swap, and I know it gets heavy. I've done several crate engine/trans swaps. That's why I'm asking, and considering staying small block. I've swapped crate 360/727 into several 318/A999 cars and all kinds of unexpected come up, I know. Mounts, linkages, driveshaft length, brackets, and on and on. Thanks.
Re: Big block swap
[Re: Guitar Jones]
#2865876
12/28/20 09:19 PM
12/28/20 09:19 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
Why not just stroke the 360? Has anyone got a 100k miles out of a stroker small block? I have read about stokers with 40k miles needing a rering already. 100k plus reliability is why I am going with a big block.
Re: Big block swap
[Re: mgoblue9798]
#2866065
12/29/20 02:39 PM
12/29/20 02:39 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Why not just stroke the 360? Has anyone got a 100k miles out of a stroker small block? I have read about stokers with 40k miles needing a rering already. 100k plus reliability is why I am going with a big block. I only have about 8k on mine, so I'll be interested in the responses on this. Never heard of issues like this on strokers.
Re: Big block swap
[Re: cudaman1969]
#2866709
12/30/20 08:40 PM
12/30/20 08:40 PM
mgoblue9798
Atlanta, GA
Shorty pistons are gonna have a lot of rock in that short bore. The reason 3.58 was the most Chrysler could push it and live a long life. Couple that with the increased side loading from the longer stroke.
Re: Big block swap
[Re: larrymopar360]
#2866793
12/30/20 11:52 PM
12/30/20 11:52 PM
Posts: 422 montana
BANDIT
montana
A few years ago, I sold all of the big block hardware off of a 77 w-100 I picked up, when I talked to the guy a little while back, he still had the stuff. PM me for his number Jim.
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
Re: Big block swap
[Re: mgoblue9798]
#2867234
12/31/20 11:10 PM
12/31/20 11:10 PM
Guitar Jones
Shorty pistons are gonna have a lot of rock in that short bore. The reason 3.58 was the most Chrysler could push it and live a long life. Couple that with the increased side loading from the longer stroke. None of those things are really an issue. The taller deck of the Mopar is still better than the chevy. I think the problem is the things run so well they get hammered on a lot. The blocks are not that great so things move around a bit especially at 7000 RPM and that is where the problems come in. If you were to build a lower RPM torque engine for a truck the reliability and longevity shouldn't be an issue.
Re: Big block swap
[Re: Guitar Jones]
#2867416
01/01/21 11:36 AM
01/01/21 11:36 AM
cudaman1969
fredericksburg,va
Shorty pistons are gonna have a lot of rock in that short bore. The reason 3.58 was the most Chrysler could push it and live a long life. Couple that with the increased side loading from the longer stroke. None of those things are really an issue. The taller deck of the Mopar is still better than the chevy. I think the problem is the things run so well they get hammered on a lot. The blocks are not that great so things move around a bit especially at 7000 RPM and that is where the problems come in. If you were to build a lower RPM torque engine for a truck the reliability and longevity shouldn't be an issue. Totally respectfully disagree.
