Stealth head question #286364
04/12/09 08:11 PM
04/12/09 08:11 PM
SE Michigan
farmington Offline OP
mopar addict
mopar addict
SE Michigan
Does anybody know if the combustion chamber on a Stealth head (or Eddy head for that matter) is compatible with the dome on the old TRW 12.5:1 pistons. I have some in my new 383 shortblock and am thinking of stepping up to alloy heads. Thanx
Re: Stealth head question [Re: farmington] #286365
04/12/09 09:34 PM
04/12/09 09:34 PM
Illinois
moparmattkos Offline
mopar addict
mopar addict
Illinois
i had +14 domes in my 400 stroker motor worked well with edelbrock rpms.
www.sikosracing.net Heads up Drag racing
Re: Stealth head question [Re: farmington] #286366
04/12/09 11:46 PM
04/12/09 11:46 PM
BC, Canada
Black_Bee Offline
Black_Bee  Offline
BC, Canada
I have the old TRW domed pistons on my 383... Stealths use a staight plug so I cant speak for those, but the angled spark plug on my Edelbrocks is not compatible with the domes.
I'm sure there are some funky spark plugs out there that would work, but I chose to whack away at the piston.
Paul
'69 Super Bee 383 EFI Turbo
Re: Stealth head question [Re: Black_Bee] #286367
04/13/09 09:03 AM
04/13/09 09:03 AM
Swamps of South Jersey.
W
wildcargo Offline
wildcargo  Offline
W
We have E-heads and 14cc Ross domes, the heads are milled .060 we use a AR3931 plug that is a non projected plug, we allso index the plug.
We were using a Arias pistion with a 17cc dome in the old motor and we notched the dome for the projeced plug AR3910, the heads were milled .040 at the time. Bouth pistions were at 0 deck
hope this helps
Bud www.wildcar-go.itgo.com
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
foot brake, leaf springs
Re: Stealth head question [Re: wildcargo] #286368
04/13/09 12:52 PM
04/13/09 12:52 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I have Ross 12.5 domes in the 440 with the Stealths.They clear.The Eddys I would have had to notch the pistons.Rocky
Chrysler Firepower
Re: Stealth head question [Re: therocks] #286369
04/13/09 02:06 PM
04/13/09 02:06 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Don't forget about deck height. Saying this will work without specifying your deck height leaves out a very CRITICAL detail...
Actually what are your deck heights and what head gasket???
Re: Stealth head question [Re: cudadoug] #286370
04/13/09 07:57 PM
04/13/09 07:57 PM
W
wildcargo Offline
wildcargo  Offline
W
You are right I went back and put 0 deck and the gasket was Cortecko .039 thickness. The AR3931 plug with the NON projected tip is the reason I did not have to notch the pistion and was able to use the E-head with the angled plug.
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
