Big Block MRE Rockers #2861090
12/16/20 11:19 PM
12/16/20 11:19 PM
Minnesota
RROD Offline OP
RROD  Offline OP
Minnesota
Are the MRE big block rocker kit sold by Mancini ok for use on a hyd roller engine? What material are the rockers made of (aluminum, chrome moly)? They look like comp cam magnum roller rockers.
Re: Big Block MRE Rockers [Re: RROD] #2861095
12/16/20 11:42 PM
12/16/20 11:42 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
They are aluminum rockers without a roller bearing and are perfectly fine for a HYD roller. They are actually made by Harland Sharp for them.
Todd
Re: Big Block MRE Rockers [Re: sasquatch] #2861100
12/16/20 11:58 PM
12/16/20 11:58 PM
Minnesota
RROD Offline OP
RROD  Offline OP
Minnesota
Thanks for the information. Their price is $300 dollars less tan comp cam magnum rockers. Always leery when a similar product is so much cheaper than the other.
Re: Big Block MRE Rockers [Re: RROD] #2861103
12/17/20 12:30 AM
12/17/20 12:30 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
OK just to check here what part number are you looking at ? The Mancini rockers look nothing like a Comp Pro magnum? They look like a Harland sharp without a bearing. The pro magnums are steel but look completely different. Todd
Re: Big Block MRE Rockers [Re: RROD] #2861172
12/17/20 09:58 AM
12/17/20 09:58 AM
Idaho
LaRoy Engines Offline
Idaho
Are you looking at the PRW rockers listed on the big block rocker arm page?
Re: Big Block MRE Rockers [Re: RROD] #2861177
12/17/20 10:10 AM
12/17/20 10:10 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
The steel ones look like PRW to me (not sure if that is what they actually are)
Rich H.
Esse Quam Videri
Re: Big Block MRE Rockers [Re: ZIPPY] #2861191
12/17/20 10:39 AM
12/17/20 10:39 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
They may well be. I have not seen Mancini selling anything like a Pro magnum UNDER their Brand. Just the bearing less HS ones. I will have to look on their website. Either way those would work as well to the original poster. I have used the PRW stainless rockers with out issues. PRW also makes an aluminum roller bearing rocker that looks like a blue Harland Sharp. I have not used those so I cannot tell you much about them.
Todd
Re: Big Block MRE Rockers [Re: sasquatch] #2861796
12/18/20 03:10 PM
12/18/20 03:10 PM
Alberta
440_Offroader Offline
Alberta
So do you need to use full time oiling on the MRE rockers since they're not roller? Also was curious about the PRW stainless Rockers. It doesn't say if they're roller or bushing style. Wondering if anyone knows for sure?
Re: Big Block MRE Rockers [Re: 440_Offroader] #2861848
12/18/20 05:34 PM
12/18/20 05:34 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
what kind of spring pressures are those MS MRE good for? I have a solid roller & my springs are getting up there.
Re: Big Block MRE Rockers [Re: 440_Offroader] #2861894
12/18/20 06:54 PM
12/18/20 06:54 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
The PRW stainless rockers are bushed on the shaft.
Re: Big Block MRE Rockers [Re: Skeptic] #2861909
12/18/20 07:23 PM
12/18/20 07:23 PM
okla.
sam64 Offline
sam64  Offline
okla.
The PRW's I bought use ball ball pushrods.
