Re: PAC spring questions
[Re: justinp61]
#2860463
12/15/20 08:17 PM
12/15/20 08:17 PM
fast68plymouth
So. Burlington, Vt.
The 1300 series “have the latest advancements” for higher endurance.
[Re: mopar dave]
#2860621
12/16/20 09:30 AM
12/16/20 09:30 AM
Posts: 13,400 Marion, South Carolina [><]
an8sec70cuda
I run the PAC 1243 on my hemi and have been very pleased w/ them. Dwayne recommended them 14 years ago. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) .672"/.651", 276°/284° at .050" solid roller.
[Re: an8sec70cuda]
#2860649
12/16/20 10:32 AM
12/16/20 10:32 AM
Posts: 9,882 MI, usa
dvw
MI, usa
I believe the 1300 series are polished. Mine runs the 1224 Pac.. When swapped at 200 passes zero pressure loss. Current set has 300 passes. Stainless 2.25 x 11/32 intake valve. 285/292@.050, .800. 7100 every pass. Doug
[Re: mopar dave]
#2860656
12/16/20 10:44 AM
12/16/20 10:44 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
That part looks good. Hughes says my Victor heads with standard valves only allow 660-680 lift max. I don't know for sure. I believe my current springs are 1.550 flat tappet springs and hoping to reuse the spring cups, titanium retainer with locks on the new Pac springs. I see CNC motorsports has the 98543(1243) pacaloy springs for $280. UDHarold cam has been ordered, so i'm on my way to roller after the T ram test run in the spring. You can get more installed height using +.050 retainers and locks. My 511 is over .700 net lift with standard length valves in my Victors. Hughes told me the same thing as you when I was figuring out the IH and camshaft. The problem I ran into was getting the roller tip centered on the valve at that lift. I used a b3 kit to correct it. Engine made peak hp around 7000-7100.
[Re: mopar dave]
#2860673
12/16/20 11:15 AM
12/16/20 11:15 AM
Jeremiah
Rogue River, OR
I will dig out the specs. It is a little different that what you will want being a power adder deal with a small tire and a stick. .740 gross, 280's @ .050, 111 LSA from Mike Jones. Maded 686hp first pull. 750 on the last pull without n20.
[Re: mopar dave]
#2860708
12/16/20 12:26 PM
12/16/20 12:26 PM
Thumperdart
State of confusion
Isky Tool Room is all you need ........Wink Wink .....
