PAC spring questions #2860437
12/15/20 07:11 PM
12/15/20 07:11 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
PAC 1243 and pac 1343 have same dimensions so. What’s the difference and which one is best for street strip .680 roller? Also Howard’s has a pacaloy 98843, same dimensions, is this the same pac spring sold under Howard’s.
Re: PAC spring questions [Re: mopar dave] #2860455
12/15/20 07:50 PM
12/15/20 07:50 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
One is a 1200 series spring and one is a 1300 series spring
That Howards spring, Comp 943, Trickflow 16943 are all relabelled PAC 1243s
Re: PAC spring questions [Re: mopar dave] #2860459
12/15/20 08:04 PM
12/15/20 08:04 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
The 1343 is listed as "1.550 Dual Spring for Short Installed Height Roller Cams", the 1343 is listed as a "1.550 Dual". I'm running the 1396 on my small block.
Re: PAC spring questions [Re: justinp61] #2860463
12/15/20 08:17 PM
12/15/20 08:17 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The 1300 series “have the latest advancements” for higher endurance.
Re: PAC spring questions [Re: fast68plymouth] #2860465
12/15/20 08:29 PM
12/15/20 08:29 PM
Cab_Burge Online work
Cab_Burge  Online Work
iagree Take a peak at PAC web site on the differences in those two part #s scope
I've used both in the past on my old Duster, I'm sticking with the 1200 part series now up twocents
Re: PAC spring questions [Re: Cab_Burge] #2860467
12/15/20 08:34 PM
12/15/20 08:34 PM
Mt Morris Michigan
Mt Morris Michigan
Ok, looks like the 1200 is good enough for what I’m doing. What application would call for the endurance of the 1300 spring?
Re: PAC spring questions [Re: mopar dave] #2860472
12/15/20 08:49 PM
12/15/20 08:49 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
A street/strip solid roller cammed, Indy headed small block that runs mid 6.20's on pump 93. biggrin
Re: PAC spring questions [Re: justinp61] #2860477
12/15/20 08:58 PM
12/15/20 08:58 PM
Mt Morris Michigan
Mt Morris Michigan
What does you cam look like?
Re: PAC spring questions [Re: mopar dave] #2860491
12/15/20 09:29 PM
12/15/20 09:29 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
263/271° @ .050" .711/.719" at the valve. The thought of the 1300 series endurance spring was that it would hold up better on the street.
Re: PAC spring questions [Re: justinp61] #2860502
12/15/20 09:52 PM
12/15/20 09:52 PM
Mt Morris Michigan
Mt Morris Michigan
That was my thought as well. After I subtract for lash I be about .668” lift if I can make that work with my victor heads and standard valves. I’m told .680 is max lift with this combo per Hughes Engines. May have to switch out the 1.6 arms for 1.5’s.
Re: PAC spring questions [Re: mopar dave] #2860532
12/15/20 11:32 PM
12/15/20 11:32 PM
The cam that is in my old S/P motor with the Eddy Victor M.W. heads has a little over .700 net lift with the Harland Sharp 1.56 ratio rocker on it, it has .120+ V to P on both valves and it is right at .080 from coil bind with the PAC valve springs I put in that motor. I did replace the springs, retainers and keepers to a set of Comp Cams 10 degree tool steel retainers and keepers with lash caps up
Re: PAC spring questions [Re: Cab_Burge] #2860553
12/16/20 12:24 AM
12/16/20 12:24 AM
Mt Morris Michigan
Mt Morris Michigan
That part looks good. Hughes says my Victor heads with standard valves only allow 660-680 lift max. I don't know for sure. I believe my current springs are 1.550 flat tappet springs and hoping to reuse the spring cups, titanium retainer with locks on the new Pac springs. I see CNC motorsports has the 98543(1243) pacaloy springs for $280. UDHarold cam has been ordered, so i'm on my way to roller after the T ram test run in the spring.
Re: PAC spring questions [Re: mopar dave] #2860621
12/16/20 09:30 AM
12/16/20 09:30 AM
an8sec70cuda Offline
I run the PAC 1243 on my hemi and have been very pleased w/ them. Dwayne recommended them 14 years ago. up
.672"/.651", 276°/284° at .050" solid roller.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: PAC spring questions [Re: an8sec70cuda] #2860649
12/16/20 10:32 AM
12/16/20 10:32 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I believe the 1300 series are polished. Mine runs the 1224 Pac.. When swapped at 200 passes zero pressure loss. Current set has 300 passes. Stainless 2.25 x 11/32 intake valve. 285/292@.050, .800. 7100 every pass.
Doug
Re: PAC spring questions [Re: dvw] #2860653
12/16/20 10:42 AM
12/16/20 10:42 AM
Mt Morris Michigan
Mt Morris Michigan
Sounds like the 1243 spring is plenty for racing. I do a lot of street so was just looking at 1343 as well. Thanks guys
Re: PAC spring questions [Re: mopar dave] #2860656
12/16/20 10:44 AM
12/16/20 10:44 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
You can get more installed height using +.050 retainers and locks. My 511 is over .700 net lift with standard length valves in my Victors. Hughes told me the same thing as you when I was figuring out the IH and camshaft. The problem I ran into was getting the roller tip centered on the valve at that lift. I used a b3 kit to correct it. Engine made peak hp around 7000-7100.
Re: PAC spring questions [Re: Jeremiah] #2860670
12/16/20 11:11 AM
12/16/20 11:11 AM
Mt Morris Michigan
Mt Morris Michigan
Wow, what size cam did you put in it? I went slightly conservative with 269/275@50 on 108.
Re: PAC spring questions [Re: mopar dave] #2860673
12/16/20 11:15 AM
12/16/20 11:15 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I will dig out the specs. It is a little different that what you will want being a power adder deal with a small tire and a stick. .740 gross, 280's @ .050, 111 LSA from Mike Jones. Maded 686hp first pull. 750 on the last pull without n20.
Re: PAC spring questions [Re: mopar dave] #2860708
12/16/20 12:26 PM
12/16/20 12:26 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Isky Tool Room is all you need ........Wink Wink .....
Re: PAC spring questions [Re: Thumperdart] #2860730
12/16/20 01:03 PM
12/16/20 01:03 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I used ISKY RAD-9998 1.600 OD springs with a 2.00ish IH.
