Call out for great service on K-Frame mods. #2859749
12/14/20 10:29 AM
12/14/20 10:29 AM
VA
dragon slayer Offline OP
VA
Just wanted to post that Al Debevec 715-267-7141 does a great job with K-frame mods and hemi k frame conversions.
Easy to work with, super quality and extremely knowledgeable. Knows the difference between a B and E body frame and brackets
Had this 70 V-8 K frame modified with brackets and insulators. Really impressed with the work, did a minor repair to a tear, and ensured the LCA pin sleeve that had a broken tack weld was reinstalled and welded properly.
If your doing a conversion, and have the K frame, I think this is a better option then the poly conversion brackets that have gotten pretty expensive.
Re: Call out for great service on K-Frame mods. [Re: dragon slayer] #2859779
12/14/20 11:58 AM
12/14/20 11:58 AM
A727Tflite Offline
A727Tflite  Offline
You can definitely tell that’s not factory welding. smile
Factory welding looks like Stevie Wonder learning to weld.
Re: Call out for great service on K-Frame mods. [Re: dragon slayer] #2859799
12/14/20 12:52 PM
12/14/20 12:52 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Al did a RB to Hemi conversion for me. Spot on great work.
Re: Call out for great service on K-Frame mods. [Re: NITROUSN] #2859858
12/14/20 03:00 PM
12/14/20 03:00 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Ed is DA MAN! He built my A-body Hemi k-frame and sets-up next to me at the Indy swap every year... up
JB Rhinehart, Realist
A-Body's RULE!
Re: Call out for great service on K-Frame mods. [Re: dragon slayer] #2860391
12/15/20 05:46 PM
12/15/20 05:46 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Did he make the brackets that bolt to the engine also, or just the ones he welds to the K frame? With the talent he obviously has, he might just be the guy that could make some of the mounts that are now abandoned since Schumaker went out of business!
Re: Call out for great service on K-Frame mods. [Re: JDMopar] #2860418
12/15/20 06:40 PM
12/15/20 06:40 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Al makes everything. All you need are studs and bolts. His engine brackets were spot on like everything else he does.
Re: Call out for great service on K-Frame mods. [Re: JDMopar] #2860435
12/15/20 07:08 PM
12/15/20 07:08 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The Schumacher mounts are now being made and sold by UCT Motorsports!
A-Body's RULE!
Re: Call out for great service on K-Frame mods. [Re: Rhinodart] #2860483
12/15/20 09:08 PM
12/15/20 09:08 PM
VA
VA
He even provided bolts. You just have to have studs in the block with nuts to put it together. Yes he makes it all. He has original samples of all but one super stock bracket I believe.
Re: Call out for great service on K-Frame mods. [Re: dragon slayer] #2860606
12/16/20 08:54 AM
12/16/20 08:54 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
What Super stock bracket does he need? I may still have some 65 hemi mounts.
Re: Call out for great service on K-Frame mods. [Re: Rhinodart] #2860643
12/16/20 10:25 AM
12/16/20 10:25 AM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
Do you have a link? Google doesn't think UCT Motorsports exists.
Re: Call out for great service on K-Frame mods. [Re: gzig5] #2860693
12/16/20 12:09 PM
12/16/20 12:09 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Al is the man! He made my 70 B-body Hemi K-Frame as well! Great craftmanship!
Re: Call out for great service on K-Frame mods. [Re: gzig5] #2860764
12/16/20 02:05 PM
12/16/20 02:05 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
US Car Tool, forgot the S...
https://store.uscartool.com/
A-Body's RULE!
Re: Call out for great service on K-Frame mods. [Re: fastmark] #2861161
12/17/20 09:15 AM
12/17/20 09:15 AM
VA
VA
I will ask him. Also, Can I get a phone number via messaging?
Re: Call out for great service on K-Frame mods. [Re: dragon slayer] #2861419
12/17/20 06:04 PM
12/17/20 06:04 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
I assume its jig mounted when being worked on to help reduce weld induced warpage issues, so why not just at the same time, weld up all the spot welds, etc?
Re: Call out for great service on K-Frame mods. [Re: jcc] #2861637
12/18/20 09:16 AM
12/18/20 09:16 AM
VA
VA
Yes he uses jigs specific to each model. Can straighten frame if damaged. I asked about that, and he recommended no. Said it made frame to rigid.
