Page 1 of 3 1 2 3
was there a LA 318 4 barrel intake from the factory? #2859545
12/13/20 07:44 PM
12/13/20 07:44 PM
md
mopars4ever Offline OP
md
Was there ever a LA 318 4 barrel intake from the factory? Is so, what was the casting number?
Re: was there a LA 318 4 barrel intake from the factory? [Re: mopars4ever] #2859549
12/13/20 07:54 PM
12/13/20 07:54 PM
Kirkland, Washington
Pacnorthcuda Offline
[u][/u]
Great question. I don’t think there was. Just like there was never a 2bbl 340 that came from the factory.
Re: was there a LA 318 4 barrel intake from the factory? [Re: mopars4ever] #2859553
12/13/20 07:57 PM
12/13/20 07:57 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Yes, mid 80s Diplomats cop car motors
Thats the only one I know of
Re: was there a LA 318 4 barrel intake from the factory? [Re: mopars4ever] #2859554
12/13/20 07:58 PM
12/13/20 07:58 PM
Yes, 1976 and later I believe scope
Mopar used some Quadra Jet carbs also in the mid 1970s, 1976 to maybe 1982 but I'm not sure if they had different intake manifolds or not than the same year Thermoquad carb. motors used shruggy
Re: was there a LA 318 4 barrel intake from the factory? [Re: mopars4ever] #2859555
12/13/20 08:02 PM
12/13/20 08:02 PM
N
NITROUSN Offline
NITROUSN  Offline
N
They were available. Not sure exactly what years. I know for sure 1980 aspens with California emissions had them. I know there were others possibly on some trucks. All the factory ones I recall would be spread bore for a thermoquad or quadrajet card. Remember most la318 heads have smaller ports. So you most likely would want 340 or 360 heads.
Re: was there a LA 318 4 barrel intake from the factory? [Re: NITROUSN] #2859556
12/13/20 08:05 PM
12/13/20 08:05 PM
md
md
Was the intake port size 318 or 360 size? Or was a 360 intake used on the 318 heads????
Re: was there a LA 318 4 barrel intake from the factory? [Re: mopars4ever] #2859557
12/13/20 08:08 PM
12/13/20 08:08 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Was the intake port size 318 or 360 size? Or was a 360 intake used on a 318????
The intake ports were larger on the 4 barrel versions. So the factory 318 engines with 4 barrel carbs would use the larger ported heads. I believe the heads were the same between the 318 and 360 4 barrel designated engines.
Re: was there a LA 318 4 barrel intake from the factory? [Re: mopars4ever] #2859565
12/13/20 08:30 PM
12/13/20 08:30 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
I had an 84 Grand Fury police sedan. It had 318 with Quadrajet carb, 360 intake and heads on it from the factory.
Re: was there a LA 318 4 barrel intake from the factory? [Re: mgoblue9798] #2859574
12/13/20 08:54 PM
12/13/20 08:54 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
318 4bbl intake? yes and no.
The factory put 360 heads and 360 4bbl intakes on 318's, so I guess technically it's a 360 4bbl intake but that's mostly hair splitting. I've put the 360 4ll intake on a normal 2bbl 318 and while some will talk about intake revision due to port size mismatch it's never been anything other than an improvement on a street car.
As for no 2bbl 260's, that's not true at all.
Re: was there a LA 318 4 barrel intake from the factory? [Re: Sniper] #2859607
12/13/20 10:15 PM
12/13/20 10:15 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Think he said "no 340 2-bbls."
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: was there a LA 318 4 barrel intake from the factory? [Re: moparmarks] #2859636
12/13/20 10:56 PM
12/13/20 10:56 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I need a new set of eyes apparently
Re: was there a LA 318 4 barrel intake from the factory? [Re: Pacnorthcuda] #2859639
12/13/20 11:00 PM
12/13/20 11:00 PM
Originally Posted by Pacnorthcuda
[u][/u]
How about three two barrels? Does that count whistling grin stirthepot
Re: was there a LA 318 4 barrel intake from the factory? [Re: Cab_Burge] #2859680
12/14/20 01:21 AM
12/14/20 01:21 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I thought that there was a 1975 Fury based Road Runner that had a 170 HP 318 4 barrel. I know that the Diplomat and Gran Fury police cars of the 80s had 318 4 barrel plants.
Re: was there a LA 318 4 barrel intake from the factory? [Re: Kern Dog] #2859698
12/14/20 05:28 AM
12/14/20 05:28 AM
moparmarks Offline
moparmarks  Offline
I also thought the 73-4 Road Runner with it's standard 318 had a 4 bbl.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: was there a LA 318 4 barrel intake from the factory? [Re: moparmarks] #2859700
12/14/20 05:44 AM
12/14/20 05:44 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
1978 was first year, a 360 intake on 318 heads. IIRC, it was a police car only option that year.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: was there a LA 318 4 barrel intake from the factory? [Re: moparmarks] #2859753
12/14/20 10:33 AM
12/14/20 10:33 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My Dad had both 73 and 74 Road Runner's with 318's brand new. They were both 2 barrel, dual exhaust. I ran the 73 at Milan Dragway. 15.90.
Doug
Re: was there a LA 318 4 barrel intake from the factory? [Re: dvw] #2859767
12/14/20 11:16 AM
12/14/20 11:16 AM
moparmarks Offline
moparmarks  Offline
Doug
Okie dokie. Good to know
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: was there a LA 318 4 barrel intake from the factory? [Re: moparmarks] #2859795
12/14/20 12:35 PM
12/14/20 12:35 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I have a 1987 E58 4 bbl quadajet 360 from a 87 PU truck.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: was there a LA 318 4 barrel intake from the factory? [Re: mopars4ever] #2859927
12/14/20 04:27 PM
12/14/20 04:27 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
When Chrysler put 4-bbl mflds onto their 318s, the intake mflds were from 360s ... and they also installed 360 cylinder heads which had the matching larger intake ports for the 360 4bbl intake... they were smart to do that.
Re: was there a LA 318 4 barrel intake from the factory? [Re: Mopar Mitch] #2859987
12/14/20 06:52 PM
12/14/20 06:52 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
For the 72-74 (??) road runners, that had the 318 in them . . . exhaust manifolds were port sized for 360 heads . . . they were even cast with "318 - RR" on them . . . note the right hand one had no heat riser drilled . . . used these on the 360 in my Sport Satellite . . .
Page 1 of 3 1 2 3
