Re: was there a LA 318 4 barrel intake from the factory?
[Re: mopars4ever]
#2859554
12/13/20 07:58 PM
12/13/20 07:58 PM
Posts: 43,218 Bend,OR USA
Cab_Burge
Was there ever a LA 318 4 barrel intake from the factory? Is so, what was the casting number? Yes, 1976 and later I believe Mopar used some Quadra Jet carbs also in the mid 1970s, 1976 to maybe 1982 but I'm not sure if they had different intake manifolds or not than the same year Thermoquad carb. motors used
[Re: mopars4ever]
#2859557
12/13/20 08:08 PM
12/13/20 08:08 PM
Posts: 18,424 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Was the intake port size 318 or 360 size? Or was a 360 intake used on a 318???? The intake ports were larger on the 4 barrel versions. So the factory 318 engines with 4 barrel carbs would use the larger ported heads. I believe the heads were the same between the 318 and 360 4 barrel designated engines.
[Re: Sniper]
#2859607
12/13/20 10:15 PM
12/13/20 10:15 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
As for no 2bbl 260's, that's not true at all. Think he said "no 340 2-bbls."
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#2859636
12/13/20 10:56 PM
12/13/20 10:56 PM
Posts: 6,280 nowhere
Sniper
nowhere
As for no 2bbl 260's, that's not true at all. Think he said "no 340 2-bbls." I need a new set of eyes apparently
[Re: moparmarks]
#2859700
12/14/20 05:44 AM
12/14/20 05:44 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
1978 was first year, a 360 intake on 318 heads. IIRC, it was a police car only option that year.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: moparmarks]
#2859753
12/14/20 10:33 AM
12/14/20 10:33 AM
Posts: 9,847 MI, usa
dvw
MI, usa
I also thought the 73-4 Road Runner with it's standard 318 had a 4 bbl. My Dad had both 73 and 74 Road Runner's with 318's brand new. They were both 2 barrel, dual exhaust. I ran the 73 at Milan Dragway. 15.90. Doug
[Re: dvw]
#2859767
12/14/20 11:16 AM
12/14/20 11:16 AM
moparmarks
I also thought the 73-4 Road Runner with it's standard 318 had a 4 bbl. My Dad had both 73 and 74 Road Runner's with 318's brand new. They were both 2 barrel, dual exhaust. I ran the 73 at Milan Dragway. 15.90. Doug Okie dokie. Good to know
[Re: moparmarks]
#2859795
12/14/20 12:35 PM
12/14/20 12:35 PM
Posts: 4,848 Memphis
HemiRick
Memphis
I have a 1987 E58 4 bbl quadajet 360 from a 87 PU truck.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: mopars4ever]
#2859927
12/14/20 04:27 PM
12/14/20 04:27 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
When Chrysler put 4-bbl mflds onto their 318s, the intake mflds were from 360s ... and they also installed 360 cylinder heads which had the matching larger intake ports for the 360 4bbl intake... they were smart to do that.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
