Re: Will these front Tires fit a 1970 Challenger?
[Re: FastOrange]
#2858967
12/12/20 02:33 PM
12/12/20 02:33 PM
Posts: 257 Alberta
440_Offroader
Alberta
I have 235 60 15's on the front of my Challenger with no problems. I do have fiberglass fenders if that makes a difference. I would think 225 70 15's would fit OK, but someone else should know for sure.
[Re: FastOrange]
#2859038
12/12/20 05:39 PM
12/12/20 05:39 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
Thanks. Using a comparison calculator, a 225 70 r 15 is 1.3" TALLER than a 235 60 15. 1.3 overall height difference is .65 larger radius. So roughly 5/8 of an inch. If the 235/60 has more space than this in any area, the 225/70 should be okay, but ride height can be a big factor. If its stock, probably no problem. If its turned down at all, it might rub. Go browsing pictures of drag cars. 27.4 overall diameter with 6" tread isn't far off from a 27x4 front runner size.
[Re: second 70]
#2859449
12/13/20 03:45 PM
12/13/20 03:45 PM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
Top picture 225/70-15 on 15x7 Torq Thrust wheels with 3.75" back spacing. Perfect fit, no rubbing. Best front tire height to match rear 28" tire.
Bottom picture 245/60-15 tire on a 15x8 wheel with 4.50" back spacing. About 1.5" shorter than the rear 275/60-15 28" tall tires. Tires will rub slightly on inside frame during full lock turn.
[Re: FastOrange]
#2859790
12/14/20 12:21 PM
12/14/20 12:21 PM
KillerBee
N.E. Ohio
That's a good sized tire under the rear, is the rear end stock width?
I stuffed 325/50-15 drag radials on 15x10 wheels under my wife's Challenger using a 1967 B body rear end and Dr. Diff's offset spring hangers.
[Re: FastOrange]
#2862765
12/20/20 10:09 PM
12/20/20 10:09 PM
Posts: 686 Houston, Texas
FastOrange
Houston, Texas
Thanks for the input! New rubber all the way around! 7" CENTERLINE Rims with 3 7/8" backspacing up front, 10" CENTERLINE Champ 500s with 5" backspacing in the rear. The rear has been modified. I can assure you that this is the absolute biggest rear tire that can be fit into a stock wheel well (leaf springs removed of course). P22570R15s Mickey Thompsons up front P31560R15s Mickey Thompsons in back
Last edited by FastOrange; 12/22/20 06:32 PM. Reason: Typo, Originally posted 70s instead of 60s on back tires
