Milodon external oiling system #2857392
12/08/20 10:51 PM
12/08/20 10:51 PM
South Dakota
dakotahotrodder Offline OP
South Dakota
Hey guys, I'm looking for pictures of the Milodon single line static external oiling system on a big block with a motor plate. The Milodon #21000 kit and the lo profile pan #30931 is what was recommended by their sales department. Thanks for the help!
Re: Milodon external oiling system [Re: dakotahotrodder] #2857458
12/09/20 03:41 AM
12/09/20 03:41 AM
I don't know all of Milidon part numbers but I have installed one of their single line external oil pickup on one of their BB/Hemi road race pans in a 1971 Challenger using a 572 pump gas Hemi EFI motor. This car has a aftermarket Oreilly tubelar front K member and their power rack and pinion steering, The car is in a body shop getting painted so no road time on it yet, I did have all the parts installed in the chassis before taking it completely apart for paint and body work
I installed the single line stationary Milidon pickup on the rear of the oil pan sump near the drain plug and made my own oil line for the pickup, it looks good and has lots of clearances between the headers, motor and oil line up
No picture though, sorry blush
Re: Milodon external oiling system [Re: Cab_Burge] #2857479
12/09/20 06:56 AM
12/09/20 06:56 AM
South Dakota
South Dakota
ok thanks. The kit doesn't work on my application and I think I may be able to get it to clear the steering with 1 fitting change. It's a '67 GTX with a motor plate, stock steering and 2" Hedman headers.
Re: Milodon external oiling system [Re: dakotahotrodder] #2857509
12/09/20 09:14 AM
12/09/20 09:14 AM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
I have the single line pickup with 2"tti headers and are motor plate. Plenty of clearance.
Re: Milodon external oiling system [Re: nss guy] #2857560
12/09/20 11:32 AM
12/09/20 11:32 AM
Georgia
66coronet Offline
66coronet  Offline
Georgia
I had to massage the steering box mounts on both our cars.
Ours are a 66 coronet with the same oil system and a motor plate with TTI step headers and a 67 coronet wagon with the same oil system and a motor plate with TTI step headers.
The oil pump cover hits the steering box mounts.
Re: Milodon external oiling system [Re: 66coronet] #2857590
12/09/20 12:31 PM
12/09/20 12:31 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Not sure about your #PNs.
[Linked Image]IMG_0059 by Greg Ault, on Flickr
[Linked Image]IMG_2249 by Greg Ault, on Flickr
Re: Milodon external oiling system [Re: gsmopar] #2857601
12/09/20 01:17 PM
12/09/20 01:17 PM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
my set up, it's a swinging pickup but I would think similar
Re: Milodon external oiling system [Re: nss guy] #2857616
12/09/20 02:04 PM
12/09/20 02:04 PM
South Dakota
South Dakota
This is pretty much how I figured it should be, and will probably make as such. The kit cam with 2- 45 degree fittings and really should have either a 45 and 90, or a straight and 90. I also need to do a little removal in the steering box mount area to be sure. It is 2020, so they probably packaged it wrong. Thanks for the help and pictures!
Re: Milodon external oiling system [Re: dakotahotrodder] #2857680
12/09/20 03:45 PM
12/09/20 03:45 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I took the long way forward but still cut the ps bracket a little.
Re: Milodon external oiling system [Re: Clanton] #2857838
12/09/20 09:38 PM
12/09/20 09:38 PM
South Dakota
South Dakota
I talked to Steve at Milodon today about my issue. It almost sounded like the may have switched from a 90 degree pan fitting to a 45 because the number 1 tube on TTI headers was in the way. I have Hedman hustler race headers and have a different issue. He told me not to put a straight union coming out of the pump cover, and that you need to have a loop up to keep the oil in the pump from draining back into the pan. He said that is what causes the priming issues. He also said that they put a 45 degree fitting on the pump and face it upward because of this. In my case, I am leaning towards a new hose with a 120 degree hose end at the pump and go to a straight hose end and 90 degree bulkhead on the pan. That should give me a little bit of loop and then pretty much straight down to the pan fitting. Does this sound reasonable? I took a couple pics of the issue that I will post also. Thanks for the replies guys!
Re: Milodon external oiling system [Re: dakotahotrodder] #2857843
12/09/20 09:44 PM
12/09/20 09:44 PM
South Dakota
South Dakota
1 picture show the best routing with the existing kit, changing the pan fitting to a 90. The other pic kind of shows what I am thinking with the loop and then down to the pan.
Re: Milodon external oiling system [Re: dakotahotrodder] #2857970
12/10/20 09:21 AM
12/10/20 09:21 AM
an8sec70cuda Offline
Here's mine on my hemi. Milodon pump w/ a stock cast iron cover and 440 Source fab'd aluminum pan.
Fits w/ a completely stock K frame and doesn't loop around anything.
CHIP
'06 GMC 2500HD LBZ Duramax
