Re: Any VCR experts here ?
[Re: Mr PotatoHead]
#2849756
11/21/20 09:34 PM
11/21/20 09:34 PM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
THANK YOU PORNtato ... I’ll tell my fiend ! And I have meself a blueray player ! Btw .... what da fugg is the diff in that and regular dvd ?
[Re: dOrk !]
#2849779
11/21/20 10:48 PM
11/21/20 10:48 PM
Posts: 20,165 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Tell him to rotate his rabbit ears antenna 180 degrees.
[Re: pittsburghracer]
#2849780
11/21/20 10:50 PM
11/21/20 10:50 PM
Posts: 9,113 Tucson, AZ
Ramrod39
My New Title
My New Title
Tucson, AZ
I just put wads of aluminum foil on them.
[Re: Jim_Lusk]
#2849961
11/22/20 02:38 PM
11/22/20 02:38 PM
dOrk !
Florida STAYcation
There is a signal on the tape that dictates playback speed at the speed it was recorded at. I don't know the layout on the tape itself, but the circuitry on the VCR may be the malfunction. Try another machine. Thx JL ... it HAS to be something like that ! ... I’ve never gotten a straight answer out of even local repair shops ... asking for a friend ! Can it be just a really extensive cleaning of the tape travel ?
[Re: Ramrod39]
#2849965
11/22/20 02:44 PM
11/22/20 02:44 PM
dOrk !
Florida STAYcation
I just put wads of aluminum foil on them. I’ve heard that doing these two things PLUS adding two HF PuttsBurger WORBLE extensions between the ears should improve the signal .... I heard that through the grapevine from that who is jsta north of Coder !
[Re: dOrk !]
#2850224
11/23/20 01:26 AM
11/23/20 01:26 AM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
There is a signal on the tape that dictates playback speed at the speed it was recorded at. I don't know the layout on the tape itself, but the circuitry on the VCR may be the malfunction. Try another machine. Thx JL ... it HAS to be something like that ! ... I’ve never gotten a straight answer out of even local repair shops ... asking for a friend ! Can it be just a really extensive cleaning of the tape travel ? Maybe, but I think it's a circuit problem. Brand new VCRs are available on Amazon, but aren't cheap...
[Re: dOrk !]
#2850798
11/24/20 12:54 AM
11/24/20 12:54 AM
Jim_Lusk
Fresno, CA
Ur probably right.... but why would it be PERFECTLY FINE in the fast SP speed ? Probably default speed.
[Re: Jim_Lusk]
#2850830
11/24/20 08:08 AM
11/24/20 08:08 AM
Posts: 19,874 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
There is a signal on the tape that dictates playback speed at the speed it was recorded at. I don't know the layout on the tape itself, but the circuitry on the VCR may be the malfunction. Try another machine. Thx JL ... it HAS to be something like that ! ... I’ve never gotten a straight answer out of even local repair shops ... asking for a friend ! Can it be just a really extensive cleaning of the tape travel ? Maybe, but I think it's a circuit problem. Brand new VCRs are available on Amazon, but aren't cheap... I had no idea they still made them, let alone that they were expensive. We're throwing ours away, along with all of our VHS tapes. It works fine, but we never use it.
Earning every penny of that moderator paycheck.
DBAP
[Re: not_a_charger]
#2851184
11/24/20 11:54 PM
11/24/20 11:54 PM
Jim_Lusk
Fresno, CA
There is a signal on the tape that dictates playback speed at the speed it was recorded at. I don't know the layout on the tape itself, but the circuitry on the VCR may be the malfunction. Try another machine. Thx JL ... it HAS to be something like that ! ... I’ve never gotten a straight answer out of even local repair shops ... asking for a friend ! Can it be just a really extensive cleaning of the tape travel ? Maybe, but I think it's a circuit problem. Brand new VCRs are available on Amazon, but aren't cheap... I had no idea they still made them, let alone that they were expensive. We're throwing ours away, along with all of our VHS tapes. It works fine, but we never use it. Don't throw it away. There is a market for good working units, especially the really good four-head stereos units. I'd like to have a couple more good working ones, but I'm not really in the market at the moment. I bought 10 or 12 Beta machines a few years ago. About half of them work good.
[Re: 360view]
#2851559
11/25/20 08:18 PM
11/25/20 08:18 PM
Jim_Lusk
Fresno, CA
I wanted to transfer some VHS tapes of family movies to DVD and then to flash drives. I have used GoVideo and Funai (Magnavox) units with VHS on one side and DVD on the other. The Funai units have HDMI outputs and have an additional 1.5 hour DVD record mode. Units like the GoVideo and Funai seem to go for about $20 in thrift stores. If the remote control is missing Dishnetwork remote controls can run them by looking up the correct code.
There is a noticeable video noise reduction “cleanup” when transferring from analog VHS to digital DVD.
These machines will reject cheap mainland china made blank DVDs and need Japan or Taiwan made blank DVDs for success.
If you then play the newly made DVD in a modern Bluray player there is a further video noise reduction.
Vupoint units can transfer VHS to SD cards. I digitize to my computer and edit the video before I put it on any media or the internet. I have the ability to do Beta, 8mm (tape, not film), VHS, mini DV, and Umatic (3/4" professional stuff). I NEED the ability to transfer 1" reel to reel video tape, but those machines are hard to find. I've got 25 more 1" tapes to do...
