School me on Dana 60 carrier for street strip #2850760
11/23/20 10:44 PM
11/23/20 10:44 PM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Hi guys, I have a D60 in my e body, it’s a 35 spline 3.74 Strange S-Trac, I’m about to order a second one for my ‘70 Roadrunner but I’m not sure which carrier to choose S-Trac or other. Reason being, currently when I pull up on the street, either foot brake it or just mash it, I only have the left wheel spinning similar to an open centre, I can’t run a spool or Detroit type locker on the street as the cops go nuts on these so I’m left with a clutch or helical gear type carrier. Give my your thoughts please?
Re: School me on Dana 60 carrier for street strip [Re: crash520] #2850783
11/23/20 11:44 PM
11/23/20 11:44 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have a Power-Lock in my Savoy and it works very well almost too tight when I'm pushing it by myself twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: School me on Dana 60 carrier for street strip [Re: crash520] #2850791
11/24/20 12:18 AM
11/24/20 12:18 AM
AndyF Offline
AndyF  Offline
The S Trac should be the best option. Not sure what is wrong with the one you have now, sounds like it isn't working correctly. Contact Cass at DoctorDiff.com and see what he recommends.
Re: School me on Dana 60 carrier for street strip [Re: AndyF] #2850810
11/24/20 02:29 AM
11/24/20 02:29 AM
usa
challenger17 Offline
usa
as Andy just posted. I have a 35 spline s-Trac and 3.73 gears in my Dana 60 and it burns both tires during burnout and the leave. You need to get your diff checked out, there is something definitely wrong. Best setup I ever had in that car.
Re: School me on Dana 60 carrier for street strip [Re: challenger17] #2850821
11/24/20 06:41 AM
11/24/20 06:41 AM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Thanks Fellas, I speak regularly with Cass, I’ve emailed Strange several times but only one answer which was what date did I buy it and nothing else, I’m sure something is up, I’ll delve into that another day, right now I need to order a diff, Cass strongly recommends the S-Trac as well so all good
Re: School me on Dana 60 carrier for street strip [Re: crash520] #2850836
11/24/20 08:35 AM
11/24/20 08:35 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
The cops get mad if you spin two tires, but they’re OK with one??? Am I not understanding this?
Re: School me on Dana 60 carrier for street strip [Re: TRENDZ] #2850845
11/24/20 09:03 AM
11/24/20 09:03 AM
W. Pa
U
usp4u Offline
usp4u  Offline
U
W. Pa
The cops probably just believe all the old tired comments about running a locker on the street......Like your car will burst into flames and flip over if you go around a turn with a locker. realcrazy
Re: School me on Dana 60 carrier for street strip [Re: usp4u] #2850901
11/24/20 12:48 PM
11/24/20 12:48 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
They probably just don't like tires squeeling or chirping turning around corners. If your talking about frying the tires in a straight line drivethen no cop on the planet is going to approve of that whether it is one tire or two. eekrunaway. Been there, done that, got the trophy. whistling
Re: School me on Dana 60 carrier for street strip [Re: GomangoCuda] #2850913
11/24/20 02:07 PM
11/24/20 02:07 PM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
They have "Anti Hooning" laws in Australia, going round a corner squealing the tyres due to a spool or just under power will earn you a ticket.
Shouldn't really have an issue with a detroit locker, it should unlock going round a corner, I don't know mine is there.
Re: School me on Dana 60 carrier for street strip [Re: Tig] #2851026
11/24/20 06:19 PM
11/24/20 06:19 PM
MN
W
Willie68coronet Offline
W
MN
I agree, I have a yukon grizzly locker in my 9" and no issues on the street with it
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear
First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
Re: School me on Dana 60 carrier for street strip [Re: Willie68coronet] #2851098
11/24/20 08:56 PM
11/24/20 08:56 PM
Brisbane Australia
crash520 Offline OP
crash520  Offline OP
Brisbane Australia
Yes the Anti Hooning laws suck here, I have been pulled over on the side of the road on a grassy gravel area and been made drive in a tight circle where had I have had a locker etc the inside wheel would have turned/slipped on the surface, guy before me had a locker and the car was pink slipped for unroad worthy FFS
Re: School me on Dana 60 carrier for street strip [Re: crash520] #2851234
11/25/20 04:02 AM
11/25/20 04:02 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
The locker in mine doesn't do that, it pretty much must disengage instantly on any turn, I also barely hear a thing, full lock or other wise. The only time I've heard it disengage, I was pushing it from the rear. I've never heard it from the inside. I don't know if some of the earlier ones were a bit "coarse" in operation but the one I got works perfect.
Re: School me on Dana 60 carrier for street strip [Re: crash520] #2851562
11/25/20 08:45 PM
11/25/20 08:45 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Too bad they took your guns away,
Re: School me on Dana 60 carrier for street strip [Re: cudaman1969] #2851617
11/25/20 10:35 PM
11/25/20 10:35 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Shooting cops at traffic stops is a proud tradition in some parts of our great nation boogie
Re: School me on Dana 60 carrier for street strip [Re: bobby66] #2851656
11/26/20 02:22 AM
11/26/20 02:22 AM
Mainly by illegals and their importers down
Re: School me on Dana 60 carrier for street strip [Re: Cab_Burge] #2851898
11/26/20 04:04 PM
11/26/20 04:04 PM
moparx Offline
moparx  Offline
NO BLASTING AT LEO'S !!! tsk flame their job is hard enough !
i have been a police commissioner since 1985, and am now the senior member.
i am VERY PROUD of our current force, and they are TRULY doing a GREAT job !
i acknowledge there are bad apples, and they are hard to deal with. [i speak from experience, and it was not pretty !]
i apologize to you guys. i went off on a rant. sorry.
please forgive me.
beer
Re: School me on Dana 60 carrier for street strip [Re: moparx] #2851901
11/26/20 04:09 PM
11/26/20 04:09 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
please forgive me.
beer
No apology needed, THANK YOU for what you do !!!!
Re: School me on Dana 60 carrier for street strip [Re: cudaman1969] #2852366
11/27/20 09:52 PM
11/27/20 09:52 PM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
[/quote]
Too bad they took your guns away, [/quote]
Yes they did - all the assault/semi auto/auto ones at least.
Still have my shotguns and Winchester big bore .375 lever.......for now.
As do millions here.
Don't believe all the crap you read online.
Re: School me on Dana 60 carrier for street strip [Re: crash520] #2852547
11/28/20 01:19 PM
11/28/20 01:19 PM
GomangoCuda Offline
GomangoCuda  Offline
I had never heard of hooning so off to google I went. All I can say is wow that sucks.
https://www.qld.gov.au/law/crime-and-police/types-of-crime/hooning
https://m.sunshinecoastdaily.com.au/news/50000-hoon-car-may-be-crushed/2415218/
Re: School me on Dana 60 carrier for street strip [Re: GomangoCuda] #2852561
11/28/20 01:59 PM
11/28/20 01:59 PM
Washington
hemienvy Offline
hemienvy  Offline
Washington
So a "Hoonigan" is someone that hoons...........
Cousin to a hooligan..........?
