Re: School me on Dana 60 carrier for street strip
[Re: crash520]
#2850836
11/24/20 08:35 AM
11/24/20 08:35 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Hi guys, I have a D60 in my e body, it’s a 35 spline 3.74 Strange S-Trac, I’m about to order a second one for my ‘70 Roadrunner but I’m not sure which carrier to choose S-Trac or other. Reason being, currently when I pull up on the street, either foot brake it or just mash it, I only have the left wheel spinning similar to an open centre, I can’t run a spool or Detroit type locker on the street as the cops go nuts on these so I’m left with a clutch or helical gear type carrier. Give my your thoughts please? The cops get mad if you spin two tires, but they’re OK with one??? Am I not understanding this?
[Re: TRENDZ]
#2850845
11/24/20 09:03 AM
11/24/20 09:03 AM
Posts: 163 W. Pa
usp4u
W. Pa
Hi guys, I have a D60 in my e body, it’s a 35 spline 3.74 Strange S-Trac, I’m about to order a second one for my ‘70 Roadrunner but I’m not sure which carrier to choose S-Trac or other. Reason being, currently when I pull up on the street, either foot brake it or just mash it, I only have the left wheel spinning similar to an open centre, I can’t run a spool or Detroit type locker on the street as the cops go nuts on these so I’m left with a clutch or helical gear type carrier. Give my your thoughts please? The cops get mad if you spin two tires, but they’re OK with one??? Am I not understanding this? The cops probably just believe all the old tired comments about running a locker on the street......Like your car will burst into flames and flip over if you go around a turn with a locker.
[Re: usp4u]
#2850901
11/24/20 12:48 PM
11/24/20 12:48 PM
Posts: 4,720 Moved to N.E. Tennessee
GomangoCuda
They probably just don't like tires squeeling or chirping turning around corners. If your talking about frying the tires in a straight line then no cop on the planet is going to approve of that whether it is one tire or two. . Been there, done that, got the trophy.
[Re: GomangoCuda]
#2850913
11/24/20 02:07 PM
11/24/20 02:07 PM
Posts: 2,916 A shed in England
Tig
A shed in England
They have "Anti Hooning" laws in Australia, going round a corner squealing the tyres due to a spool or just under power will earn you a ticket. Shouldn't really have an issue with a detroit locker, it should unlock going round a corner, I don't know mine is there.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#2851026
11/24/20 06:19 PM
11/24/20 06:19 PM
Posts: 277 MN
Willie68coronet
MN
I agree, I have a yukon grizzly locker in my 9" and no issues on the street with it
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
[Re: crash520]
#2851234
11/25/20 04:02 AM
11/25/20 04:02 AM
Tig
A shed in England
Yes the Anti Hooning laws suck here, I have been pulled over on the side of the road on a grassy gravel area and been made drive in a tight circle where had I have had a locker etc the inside wheel would have turned/slipped on the surface, guy before me had a locker and the car was pink slipped for unroad worthy FFS The locker in mine doesn't do that, it pretty much must disengage instantly on any turn, I also barely hear a thing, full lock or other wise. The only time I've heard it disengage, I was pushing it from the rear. I've never heard it from the inside. I don't know if some of the earlier ones were a bit "coarse" in operation but the one I got works perfect.
[Re: crash520]
#2851562
11/25/20 08:45 PM
11/25/20 08:45 PM
Posts: 8,250 fredericksburg,va
cudaman1969
fredericksburg,va
Yes the Anti Hooning laws suck here, I have been pulled over on the side of the road on a grassy gravel area and been made drive in a tight circle where had I have had a locker etc the inside wheel would have turned/slipped on the surface, guy before me had a locker and the car was pink slipped for unroad worthy FFS Too bad they took your guns away,
[Re: cudaman1969]
#2851617
11/25/20 10:35 PM
11/25/20 10:35 PM
Posts: 3,805 Arlington, Texas
bobby66
Arlington, Texas
Yes the Anti Hooning laws suck here, I have been pulled over on the side of the road on a grassy gravel area and been made drive in a tight circle where had I have had a locker etc the inside wheel would have turned/slipped on the surface, guy before me had a locker and the car was pink slipped for unroad worthy FFS Too bad they took your guns away, Shooting cops at traffic stops is a proud tradition in some parts of our great nation
[Re: bobby66]
#2851656
11/26/20 02:22 AM
11/26/20 02:22 AM
Posts: 43,157 Bend,OR USA
Cab_Burge
Yes the Anti Hooning laws suck here, I have been pulled over on the side of the road on a grassy gravel area and been made drive in a tight circle where had I have had a locker etc the inside wheel would have turned/slipped on the surface, guy before me had a locker and the car was pink slipped for unroad worthy FFS Too bad they took your guns away, Shooting cops at traffic stops is a proud tradition in some parts of our great nation Mainly by illegals and their importers
[Re: Cab_Burge]
#2851898
11/26/20 04:04 PM
11/26/20 04:04 PM
Posts: 19,388 north of coder
moparx
NO BLASTING AT LEO'S !!! their job is hard enough ! i have been a police commissioner since 1985, and am now the senior member. i am VERY PROUD of our current force, and they are TRULY doing a GREAT job ! i acknowledge there are bad apples, and they are hard to deal with. [i speak from experience, and it was not pretty !] i apologize to you guys. i went off on a rant. sorry. please forgive me.
[Re: moparx]
#2851901
11/26/20 04:09 PM
11/26/20 04:09 PM
Posts: 2,857 Pattison Texas
CSK
Pattison Texas
NO BLASTING AT LEO'S !!! their job is hard enough ! i have been a police commissioner since 1985, and am now the senior member. i am VERY PROUD of our current force, and they are TRULY doing a GREAT job ! i acknowledge there are bad apples, and they are hard to deal with. [i speak from experience, and it was not pretty !] i apologize to you guys. i went off on a rant. sorry. please forgive me. No apology needed, THANK YOU for what you do !!!!
