Todays Question :0) Carb Spacers #284614
04/11/09 12:40 PM
04/11/09 12:40 PM
U.S.
moparniac Offline OP
U.S.
I know its vague and combos vary but Im gonna get a carb spacer and the 4 hole is good for mid range and the open is good for top end power.... anyone have any track/dyno results between the 2...
My old setup was a 4150 to 4500 adapter setup. no room for that now
thx
Mopar Performance
Re: Todays Question :0) Carb Spacers [Re: moparniac] #284615
04/11/09 12:58 PM
04/11/09 12:58 PM
AndyF Offline
AndyF  Offline
It just depends on what the combination wants. I usually start with a 4 to 1 merge spacer for single plane intakes. For a dual plane intake I usually start with a 1 inch open spacer.
For high speed engines a shear plate usually works better than a spacer but most bracket racers run simple spacers. You usually only see the shear plate setups on the higher dollar motors although they don't really cost much to buy.
Re: Todays Question :0) Carb Spacers [Re: AndyF] #284616
04/11/09 04:08 PM
04/11/09 04:08 PM
U.S.
U.S.
andy I think it was one of your MM articles that you said you like the cloverleaf spacer.... helped pickup flow or something..
Mopar Performance
Re: Todays Question :0) Carb Spacers [Re: moparniac] #284617
04/11/09 04:22 PM
04/11/09 04:22 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you only get 1 post per day
Re: Todays Question :0) Carb Spacers [Re: Quicktree] #284618
04/11/09 08:21 PM
04/11/09 08:21 PM
U.S.
U.S.
Per Hour
Mopar Performance
