Re: 4 speed installation
[Re: Kippy]
#2842524
11/06/20 12:29 PM
11/06/20 12:29 PM
Posts: 25,982 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I've never had any luck trying to install the fork with the bearing in, others claim to have done it.
Can you lower the engine more to get a straighter shot or is the pan sitting on the steering link?
[Re: Kippy]
#2842579
11/06/20 02:42 PM
11/06/20 02:42 PM
Posts: 2,081 CA
crackedback
CA
heat is your friend on those mount plate bolts.
After heating up the bosses, take a punch or drift, drop it into the allen key hole and give it a good smack with a hammer. Shock will help break the bond.
[Re: Kippy]
#2842612
11/06/20 04:12 PM
11/06/20 04:12 PM
Posts: 43,300 Bend,OR USA
Cab_Burge
Which motor is in your car? If it is a 383 you may need to change the crankshaft from the automatic tranny to a stick shift tranny Did you install a pilot bearing into the crankshaft? if not they need it also If it is a original automatic tranny 440 you may need to do that also I'm not sure about the SB motors on this issue
[Re: Cab_Burge]
#2842684
11/06/20 07:55 PM
11/06/20 07:55 PM
Posts: 12,245 Looking for a way out of Middl...
IMGTX
I pulled an A904 automatic out of an unmolested, original engine and transmission, 74 Satellite Sebring 318. The Crankshaft was not only drilled for a pilot bushing it had one installed already. I have to wonder if there is any rhyme or reason for some of the things ma mopar does.
[Re: crackedback]
#2843411
11/08/20 11:18 AM
11/08/20 11:18 AM
Posts: 350 Mequon, WI
gzig5
Mequon, WI
After heating up the bosses, take a punch or drift, drop it into the allen key hole and give it a good smack with a hammer. Shock will help break the bond. Flat head allen bolts like those have a tendancy to stick because of the larger surface area under the head getting a good grip. Use heat and shock as mentioned and it that doesn't loosen them up, take a center punch and use it to drive the screw loose by hitting it at an angle out near the periphery of the head. I have removed tons of stainless flat heads this way and it works on carbon steel as well.
[Re: gzig5]
#2843422
11/08/20 11:43 AM
11/08/20 11:43 AM
Posts: 1,849 South Bend
John Brown
South Bend
After heating up the bosses, take a punch or drift, drop it into the allen key hole and give it a good smack with a hammer. Shock will help break the bond. Flat head allen bolts like those have a tendancy to stick because of the larger surface area under the head getting a good grip. Use heat and shock as mentioned and it that doesn't loosen them up, take a center punch and use it to drive the screw loose by hitting it at an angle out near the periphery of the head. I have removed tons of stainless flat heads this way and it works on carbon steel as well. Motorcycle style impact wrench might help out to.
[Re: AndyF]
#2843553
11/08/20 05:16 PM
11/08/20 05:16 PM
Posts: 59 USA
Kippy
USA
I can't imagine trying to do an install under a car anymore. I just put the Doug Nash back together with my engine and it took some work doing on the floor. I had to use the input shaft to double check the fit a couple of times before it would all slide together. That same job would be impossible for me if the engine was in the car. Wow!! Thats very nice Andy... I had the car far enough up so I have enough room but I can see that my days working on my back under a car might be numbered. Exactly last Sunday while under the car I got a bad case of vertigo I had to close my eyes everything was spinning. I got up shut the lights and made my way into the house and called it a day.... I get vertigo every so often... Im happy to report the trans is bolted up... I had read were its said the input shaft may be long for a car with a crankshaft from a auto trans car....Measuring that wasn't the case and so i tried to instill the trans but it wouldn't go all the way in What I found was it was the diameter at the end of the machined hole in crankshaft, it was a smaller diameter then the input shaft, The input shaft was already through the pilot bearing that I gotten from Brewers performance. I measured and cut off about a inch and a quarter of the end of the input shaft, beveled and dressed it up and problem solved Much thanks to members here with their advise and help--------------------Steve
[Re: Kippy]
#2845089
11/11/20 09:21 PM
11/11/20 09:21 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
Leave the spring with a Borg Beck "3 finger" plate remove it with a diaphragm plate is the general rule but I removed mine when I installed a Long style plate. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
