New aftermarket speedo gears on Amazon #2838345
10/28/20 01:55 PM
10/28/20 01:55 PM
GA
roadrunninMark Offline OP
GA
Just found these on Amazon, price is good too. Looks like the o rings are included and they have different tooth counts.. https://www.amazon.com/Speedometer-...mp;psc=1&refRID=R3HVNM4PH36HSDBFMZD6
Re: New aftermarket speedo gears on Amazon [Re: roadrunninMark] #2838425
10/28/20 04:57 PM
10/28/20 04:57 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I wonder if the new gears from brewers for $44 are the same as the $27 LA gears?
Re: New aftermarket speedo gears on Amazon [Re: mopars4ever] #2838445
10/28/20 05:45 PM
10/28/20 05:45 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Here's a link to all the items the seller has listed.
-> American Hot Rod Solutions (speedo parts) listed on Amazon <-
Re: New aftermarket speedo gears on Amazon [Re: John Brown] #2838530
10/28/20 10:01 PM
10/28/20 10:01 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I bought quite a few gears from these guys for Mopars and GM trans. All looked good and fit good and you can't beat the prices Some of the vendors are asking crazy money for the 3X number gears.
The only Carbs I care about are under the hood!
Re: New aftermarket speedo gears on Amazon [Re: Azzkikrcuda] #2839093
10/29/20 11:28 PM
10/29/20 11:28 PM
5thAve Offline
5thAve  Offline
now it says no longer available... OK who bought them all to flip??? laugh2
Re: New aftermarket speedo gears on Amazon [Re: 5thAve] #2839315
10/30/20 02:03 PM
10/30/20 02:03 PM
Lebanon ,PA in the Susquehanna...
70Challengerse Offline
I just bought the last ones of the 31 and 33 mopar... up
Re: New aftermarket speedo gears on Amazon [Re: 70Challengerse] #2839510
10/30/20 11:11 PM
10/30/20 11:11 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
Hey, so if you all don't mind - can you school me a little on speedo gears?
What I have is a speedo that reads high by about 10%.
So the existing gear is spinning too fast.
I'm pretty sure that means I should try a gear with 10% more teeth?
When I pull the existing gear out to count its teeth, is that a dry location, or will the tranny fluid want to leak out?
Thanks,
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: New aftermarket speedo gears on Amazon [Re: 67SATisfaction] #2839681
10/31/20 11:22 AM
10/31/20 11:22 AM
AndyF Offline
AndyF  Offline
That is correct, you need more teeth on the gear. If the car is level or if the nose is down a little there shouldn't be any fluid coming out. Jack up the rear axle for clearance to get under the car and you should be fine. The FSM has a chart showing which speedo gears are used with which rear gears and tires.
Re: New aftermarket speedo gears on Amazon [Re: Azzkikrcuda] #2839682
10/31/20 11:23 AM
10/31/20 11:23 AM
AndyF Offline
AndyF  Offline
I have a box of used gears that I've pulled out of 727 transmissions over the years. Guess that is my retirement fund now!
Re: New aftermarket speedo gears on Amazon [Re: 67SATisfaction] #2839684
10/31/20 11:29 AM
10/31/20 11:29 AM
moparx Offline
moparx  Offline
your 10% is roughly correct. however, it could factor out to one tooth higher or lower than is available.
as to changing out the gear, jack up the driver's side of the car and support on stands.
the area is wet, and this will greatly minimize, if not entirely eliminate the fluid loss.
have a pan under just in case, to keep your floor clean.
beer
Re: New aftermarket speedo gears on Amazon [Re: moparx] #2839962
10/31/20 10:52 PM
10/31/20 10:52 PM
GA
GA
67, here is a chart to help you choose the correct speedo gear, based on tire size and rear gear ratio. I don't know if the correlation of 10% speed off on the speedo is going to equal needing 10% more teeth. That sounds like a large jump in number of teeth, unless you have a low 20s # then it isn't as big as a jump compared to a 30s #. This is just me thinking though. If you can tell us what your gear ratio is and tire diameter now, plus what tooth count gear is in there, it would help.
http://www.moparts.org/Tech/tech/img/chart.jpg
Re: New aftermarket speedo gears on Amazon [Re: roadrunninMark] #2840136
11/01/20 12:58 PM
11/01/20 12:58 PM
Albany, NY
Albany, NY
Thanks very much for the detailed info guys, that is super helpful..
I've got the 1965 FSM, and will have a closer look at it along with the chart in the link:
- I know I've got a 2.76 rear end, and running 225/70 14s = diameter of 26.4" ... so the chart suggests 27 or 28 teeth.
I'll have to pull the existing gear to get its number of teeth for comparison.
It's in winter storage already but I can bring a jack and try getting that done.
Cheers,
- Art
