Off road/Truck tires #2378541
09/28/17 11:18 PM
09/28/17 11:18 PM
Kirkland, Washington
Pacnorthcuda Offline OP
I recently retired and moved out in "the country". I am doing a LOT more off roading. Some of it on some pretty rough roads as far as tires go. Sharp rocks.
I am learning some things I never knew, or at least never had to concern myself with.
1997 Toyota 4Runner (winter, off road beater). BFG "Long Trail T/A".
I have had three flat tires in the last two months.
Turns out these 'soft balloons' (my term) are 4 ply tires which are fine on the highway, and snow on asphalt, but little else.
I need to better match my rig to its usage.
I am learning about load ratings and 6 ply, 10 ply (which apparently doesn't really mean the ply count, just an equivalent to the construction back in the days when it did.
I don't want sharp rocks piercing my tires.
Advice, experience?
Re: Off road/Truck tires [Re: Pacnorthcuda] #2378577
09/28/17 11:58 PM
09/28/17 11:58 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Here's what I run on the Dodge Power Wagon as the truck sees street, off road/dirt/mud pits, rock climbing, basic off road mayhem, 10 ply Thornbirds, great year round, even snow, great off road, dirt or mud, heavy construction long wearing go anywhere, do anything tire, these are 38X12.5X17 weigh in at about 70 lbs each just for the tire, I got these thru Summit, they're made by the same company making M&H Racemasters...made in the USA, not overseas
If you get into TSL type tires they are difficult to balance, I use the large diameter ceramic off road DYNABEADS to balance them, very effective!
Here's my little "tire gauge" inspecting...
Re: Off road/Truck tires [Re: Pacnorthcuda] #2378579
09/29/17 12:04 AM
09/29/17 12:04 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Thats probably the first positive review I have read about thornbirds haha, they look cool!
I think anything BFG makes has a less than desirable sidewall. I had tons of trouble with the 33x12.50 BFG mud terrains when I had them on my Xj Cherokee. The tire shop made the mistake of selling me a warranty and boy did they regret it lol. When I moved to a 35x12.50 I got some of the GoodYear Kevlar MTRs and they have been great with zero sidewall cuts. They are 7 years old now and getting pretty hard so it is almost time to replace them frown.
68 Barracuda Formula S 340
Re: Off road/Truck tires [Re: Pacnorthcuda] #2378582
09/29/17 12:10 AM
09/29/17 12:10 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Toyo M/Ts or Nitto Trail Grapplers. Very, very good tires in both performance and durability.
Just look at the weight of the Toyo vs something like a KM2, it tells you what you need to know.
I ran 37" Trail Grapplers @ 4psi when off-road on my [then] daily driver. With that low of tire pressure, ram-assist steering, lockers and a 4:1 transfer case...I was very hard on tires. I wouldn't bother with anything but a tire from Toyo or Nitto if you are getting serious at all. I ran 35" KM2s and was not impressed with them at all, they are also "short" and are not true to size.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Off road/Truck tires [Re: Pacnorthcuda] #2378586
09/29/17 12:15 AM
09/29/17 12:15 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
My tires during the same trip, no issues.
2020 RAM 1500
Re: Off road/Truck tires [Re: GoodysGotaCuda] #2378591
09/29/17 12:25 AM
09/29/17 12:25 AM
Wow, that's an incredible shot Goody! More than I subject my stuff to.
Re: Off road/Truck tires [Re: Pacnorthcuda] #2378670
09/29/17 06:23 AM
09/29/17 06:23 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Recommend an E load BFG KO2 all terrain tire.
Reviews are excellent. I just put some on my 01 Ram.
Re: Off road/Truck tires [Re: Pacnorthcuda] #2378736
09/29/17 11:40 AM
09/29/17 11:40 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I've been running the BFG All Terrains for years and I like them. My jeep saw a lot of off-roading, lots of time in the gravel pits and they still drive well on the street. Never put them through the sharp rocks like in goody's pic though.
Re: Off road/Truck tires [Re: Pacnorthcuda] #2378748
09/29/17 11:54 AM
09/29/17 11:54 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Wow, that looks like a tire destruction tool!
Re: Off road/Truck tires [Re: Pacnorthcuda] #2378766
09/29/17 12:20 PM
09/29/17 12:20 PM
scratchnfotraction Offline
well here in the swamps it used to be the gateway gumbo monster mudders in the 14/35/15 to the 18/44/15 then the ground hawgs 14/35 or 17/40 or 18/44
now days I run the 34x9.50x15 TSL super swamper on my yota 4x4
one thing to remember in the mud is 35s don't go where 44s have been.
I have to say the thornbird is a good narly looking tire and has a long wear life on pavement. good Baja tire with tuff sidewalls.
but the ones I ran on the jeep were 33x13.50x15 on 12 rims. little to short to get off in the deep but were awesome in the sand drags.
IMHO, tall skinny tires work just as good as tall wide tires with less bearing failures from wide rim leverage.
Re: Off road/Truck tires [Re: scratchnfotraction] #2378769
09/29/17 12:23 PM
09/29/17 12:23 PM
yes, Goodys is extreme off roading! good sidewall and low air pressures = traction!
cyprees knees do the same thing to tires in the swamps, you just don't see the underwater action when it does.
Re: Off road/Truck tires [Re: Pacnorthcuda] #2378871
09/29/17 02:51 PM
09/29/17 02:51 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Goodyear Duratracs are extremely popular around here. I'm getting a set this winter for my winter tires. From the guys I talked to they are fairly quiet, wear well and very tough
Re: Off road/Truck tires [Re: Pacnorthcuda] #2378944
09/29/17 05:01 PM
09/29/17 05:01 PM
enfield, CT
ViperDave Offline
ViperDave  Offline
enfield, CT
my offroad tire of choice is interco TRXUS STS. have had great luck with them in all weather conditions and offroad on several dedicated offroad vehicles
67 Dart GT Vert 273/904
72 Town & Country 440/727
90 D350 reg cab dually cummins
15 Scat Pack Challenger
Re: Off road/Truck tires [Re: ViperDave] #2382137
10/04/17 11:20 PM
10/04/17 11:20 PM
Alberta
440_Offroader Offline
Alberta
I recently was looking for a dual purpose tire. There are so many tires out there, it's a little crazy. My results were the same as Goodys. Toyo M/Ts or the Nitro Trail Grapplers.
I had the Toyo M/Ts on a work truck a few years ago. They still performed well, even with them worn to the wear bars. I have some Duratracs on a truck right now, but it's mostly street driven. The Duratracs do work excellent in the snow. Never a flat on either tires.
Definitely go for a heavier tire. Might bring fuel mileage down a little, but a thicker carcass will be more resistant to tire cutting obstacles.
Lots of choices, good luck with whatever you choose.
Re: Off road/Truck tires [Re: 440_Offroader] #2837217
10/25/20 10:48 AM
10/25/20 10:48 AM
Hercules, CA. United States
Darren11 Offline
Darren11  Offline
Best tire for 2010 RAM 1500 4x4
Hi, I need your recommendations because my job will require me to tow a trailer and I’d be travelling highways and off road. I have the stock tires and I am in need of a light truck tire that is comfortable on the highways and yet durable when off road.
Do I need bigger and wider tires? If I go for a rim size 20 what tire specs would you recommend without lifting the truck?
I have been trying to research the best tires for RAM and found a good article and here is the linklink. I am close to getting 265/70/17 Michellin LTX via Amazon . I am about to pull the trigger. Any 2nd opinions?
Re: Off road/Truck tires [Re: WO23Coronet] #2837312
10/25/20 02:50 PM
10/25/20 02:50 PM
Central Florida
larrymopar360 Online content
Stud Muffin
larrymopar360  Online Content
Stud Muffin
Central Florida
That's what my Power Wagon (79) had when I bought it and still does. Fairly quiet on road, did well in mud. Don't know about really rough terrain, but a friend raves about them on his Phord for off-roading and durability.
Facts are stubborn things.
Re: Off road/Truck tires [Re: larrymopar360] #2838181
10/28/20 12:37 AM
10/28/20 12:37 AM
Darren11 Offline
Darren11  Offline
Hi I will look into this Goodyear Duratracs, hopefully it's close to my budget. Thanks! Appreciate it.
Re: Off road/Truck tires [Re: Darren11] #2838235
10/28/20 09:23 AM
10/28/20 09:23 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
My only advice is to comparison shop for what you see on summit, so you can get a price match and free shipping. I got the Falken Wildpeak A/T3W from there after price matching (to either Walmart or Amazon, can't remember) and it saved me a lot in shipping and (at the time) sales tax.
Re: Off road/Truck tires [Re: Pacnorthcuda] #2838277
10/28/20 10:58 AM
10/28/20 10:58 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
I have Hankook Dynapro ATM tires on my ram. They're 10-ply, quiet on the streets and hold up great in the North Florida woods. Not sure how they'd hold up in an environment with sharp rocks. Oh, and fairly inexpensive for a truck tire. I recommend you look into them while you're tire shopping.
Re: Off road/Truck tires [Re: Fat_Mike] #2838291
10/28/20 11:31 AM
10/28/20 11:31 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Duratrac's on my 2015 Power Wagon. 285/70-17 D rated from the factory. Went 56,000 and still had life. Overall a good tire and I went with them again.
