Disk brake conversion question #2836681
10/23/20 07:40 PM
10/23/20 07:40 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Can 68-70 B/E-body disk brake assemblies (less the spindles) be installed on an A-body if using 73-76 A-body spindles?
Re: Disk brake conversion question [Re: 6PAX] #2836690
10/23/20 07:52 PM
10/23/20 07:52 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
nope
Re: Disk brake conversion question [Re: 6PAX] #2836692
10/23/20 07:54 PM
10/23/20 07:54 PM
AndyF Offline
AndyF  Offline
No, you would have to use the B/E knuckles. Just bolt the whole assembly on there. Those brakes aren't as good as the '73+ brakes but they'll fit and work if that is all you have.
Re: Disk brake conversion question [Re: AndyF] #2836819
10/24/20 08:03 AM
10/24/20 08:03 AM
VA
dragon slayer Offline
VA
There is no 68-70 B/E system. There is a 67-69 B body spindle, and there is a 70-72 B/E spindle. 67-69 B was a bendix system with different caliper and mount and rotor. 70-72 B/E used the Kelsey Hayes system single piston caliper, bracket and different size rotor.
Re: Disk brake conversion question [Re: dragon slayer] #2836826
10/24/20 08:34 AM
10/24/20 08:34 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Didn't at least some '70 E bodies have a 2 piston caliper? Seems like I ran into that years ago.
Master, again and still
Re: Disk brake conversion question [Re: DaveRS23] #2836832
10/24/20 08:52 AM
10/24/20 08:52 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
No, all 70-74 E body used the single piston 2 pin caliper.... Dragon Slayer gave you the appropriate year applications above your last post...
FYI, the 73-4 E body rotors use the larger inner rear bearing and 1 pc rotors, as do all 73 up disc applications, the 70-72 E/B spindles/rotors use the smaller inner rear bearing and 2 pc rotor, hence 2 E body spindles, the 73 and up B body spindle is the "tall" spindle, similar to the F/M/J body slider caliper spindle....
Mike
Re: Disk brake conversion question [Re: AndyF] #2837566
10/26/20 02:06 PM
10/26/20 02:06 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Ok, so if I use the B-body assemblies including the B-body spindles, will there be any issues regarding the upper or lower control arms? These would be going on a 70 Dart which currently has sbp disks.
Re: Disk brake conversion question [Re: 6PAX] #2837572
10/26/20 02:25 PM
10/26/20 02:25 PM
BDW Offline
BDW  Offline
Re: Disk brake conversion question [Re: 6PAX] #2837574
10/26/20 02:30 PM
10/26/20 02:30 PM
AndyF Offline
AndyF  Offline
Yes there will be an issue with the upper control arm, the ball joint is too small on a '70.
Re: Disk brake conversion question [Re: 6PAX] #2837661
10/26/20 05:25 PM
10/26/20 05:25 PM
Cab_Burge Online work
Cab_Burge  Online Work
Get yourself the 1973 V8 and up A body spindles, brakes and A arm and lower control arm, rotor with the 4.5 inch bolt pattern hub, and bolt it in and go stop better up scope
I did that to my 1971 Duster street and strip, it stopped fine in the 1/4 mile running 134.+ MPH weighing 3450 Lbs. with me in that car up
I used all the parts from a 1974 318 Duster with those stock disc brakes up wrench
I think the 1973 6 cylinder cars still had the small 4.0 inch bolt pattern them, Mopar drop them, the 4.0 bolt pattern, in 1974 is what i was told on here about them in 2002 or so when I built that car shruggy
I did mount the brake caliper so it was mounted behind the spindle by reversing the spindles from the right side to the left and vise a versus, it aligned fine and stop great with that change up scope That help move some of the weight back towards the rear of the car helping traction without being seen devil up
Re: Disk brake conversion question [Re: AndyF] #2837942
10/27/20 11:35 AM
10/27/20 11:35 AM
moparx Offline
moparx  Offline
[quote=AndyF][quote=6PAX]
dr. diff has ball joint adapters that will allow the small ball joint to fit the B-body spindle.
i used these on my buddy's 72 duster and they worked great !
beer
Re: Disk brake conversion question [Re: moparx] #2838059
10/27/20 05:18 PM
10/27/20 05:18 PM
AndyF Offline
AndyF  Offline
That is one solution.
Re: Disk brake conversion question [Re: AndyF] #2838123
10/27/20 08:59 PM
10/27/20 08:59 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
If I use 73-up A-body upper control arms, will that do the trick?
Re: Disk brake conversion question [Re: 6PAX] #2838157
10/27/20 10:36 PM
10/27/20 10:36 PM
AndyF Offline
AndyF  Offline
Yes, that is another option.
Re: Disk brake conversion question [Re: AndyF] #2838320
10/28/20 12:56 PM
10/28/20 12:56 PM
moparx Offline
moparx  Offline
i forgot to say, the reason i/my buddy went with the upper ball joint adapters, was the upper arms came with new bushings and ball joints already installed.
if your upper arms need any parts, just replace the arms with the newer style and be done.
beer
