Re: Disk brake conversion question
[Re: 6PAX]
#2836690
10/23/20 07:52 PM
10/23/20 07:52 PM
Posts: 21,442 It's a dry heat
gtx6970
It's a dry heat
Can 68-70 B/E-body disk brake assemblies (less the spindles) be installed on an A-body if using 73-76 A-body spindles? nope
[Re: 6PAX]
#2836692
10/23/20 07:54 PM
10/23/20 07:54 PM
Posts: 31,042 Oregon
AndyF
Can 68-70 B/E-body disk brake assemblies (less the spindles) be installed on an A-body if using 73-76 A-body spindles? No, you would have to use the B/E knuckles. Just bolt the whole assembly on there. Those brakes aren't as good as the '73+ brakes but they'll fit and work if that is all you have.
[Re: AndyF]
#2836819
10/24/20 08:03 AM
10/24/20 08:03 AM
Posts: 1,326 VA
dragon slayer
VA
There is no 68-70 B/E system. There is a 67-69 B body spindle, and there is a 70-72 B/E spindle. 67-69 B was a bendix system with different caliper and mount and rotor. 70-72 B/E used the Kelsey Hayes system single piston caliper, bracket and different size rotor.
[Re: dragon slayer]
#2836826
10/24/20 08:34 AM
10/24/20 08:34 AM
Posts: 12,108 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Didn't at least some '70 E bodies have a 2 piston caliper? Seems like I ran into that years ago.
Master, again and still
[Re: DaveRS23]
#2836832
10/24/20 08:52 AM
10/24/20 08:52 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Didn't at least some '70 E bodies have a 2 piston caliper? Seems like I ran into that years ago. No, all 70-74 E body used the single piston 2 pin caliper.... Dragon Slayer gave you the appropriate year applications above your last post... FYI, the 73-4 E body rotors use the larger inner rear bearing and 1 pc rotors, as do all 73 up disc applications, the 70-72 E/B spindles/rotors use the smaller inner rear bearing and 2 pc rotor, hence 2 E body spindles, the 73 and up B body spindle is the "tall" spindle, similar to the F/M/J body slider caliper spindle.... Mike
[Re: AndyF]
#2837566
10/26/20 02:06 PM
10/26/20 02:06 PM
Posts: 5,623 Detroit area
6PAX
Detroit area
Can 68-70 B/E-body disk brake assemblies (less the spindles) be installed on an A-body if using 73-76 A-body spindles? No, you would have to use the B/E knuckles. Just bolt the whole assembly on there. Those brakes aren't as good as the '73+ brakes but they'll fit and work if that is all you have. Ok, so if I use the B-body assemblies including the B-body spindles, will there be any issues regarding the upper or lower control arms? These would be going on a 70 Dart which currently has sbp disks.
[Re: 6PAX]
#2837572
10/26/20 02:25 PM
10/26/20 02:25 PM
Posts: 4,730 Florida
BDW
[Re: 6PAX]
#2837574
10/26/20 02:30 PM
10/26/20 02:30 PM
AndyF
Can 68-70 B/E-body disk brake assemblies (less the spindles) be installed on an A-body if using 73-76 A-body spindles? No, you would have to use the B/E knuckles. Just bolt the whole assembly on there. Those brakes aren't as good as the '73+ brakes but they'll fit and work if that is all you have. Ok, so if I use the B-body assemblies including the B-body spindles, will there be any issues regarding the upper or lower control arms? These would be going on a 70 Dart which currently has sbp disks. Yes there will be an issue with the upper control arm, the ball joint is too small on a '70.
[Re: AndyF]
#2837942
10/27/20 11:35 AM
10/27/20 11:35 AM
Posts: 19,421 north of coder
moparx
[quote=AndyF][quote=6PAX] Ok, so if I use the B-body assemblies including the B-body spindles, will there be any issues regarding the upper or lower control arms? These would be going on a 70 Dart which currently has sbp disks. Yes there will be an issue with the upper control arm, the ball joint is too small on a '70. dr. diff has ball joint adapters that will allow the small ball joint to fit the B-body spindle. i used these on my buddy's 72 duster and they worked great !
[Re: moparx]
#2838059
10/27/20 05:18 PM
10/27/20 05:18 PM
AndyF
