Best ring pack for pan evac equiped race bb? #2833933
10/17/20 04:32 PM
10/17/20 04:32 PM
gregsdart Offline OP
Curious how thin a ring pack and what tension can be used with a pan evac system? 512 bigblock bracket motor.
Re: Best ring pack for pan evac equiped race bb? [Re: gregsdart] #2833935
10/17/20 04:35 PM
10/17/20 04:35 PM
AndyF Offline
AndyF  Offline
Good question. Hook a pressure sending unit up to your data logger and see what the numbers are. Personally I don't trust a pan evac system to do much of anything. If the engine had a vacuum pump then I'd go with a metric ring pack. We've used the Mahle 1/1/3 mm ring packs and they free up some power that is for sure.
Re: Best ring pack for pan evac equiped race bb? [Re: AndyF] #2833961
10/17/20 05:27 PM
10/17/20 05:27 PM
No running motor at this time, just some pistons with .043/.043/3/16 ring pack. I have considered what to do with the megablock that i split a cylinder in. Fix it, or sell it and a potential buyer doesn't use a vacuum pump. The pistons and rings in seven cylinders only have seven runs on them, and could be built pretty reasonably for what he wants if the .043 rings will work.
Re: Best ring pack for pan evac equiped race bb? [Re: gregsdart] #2833975
10/17/20 06:09 PM
10/17/20 06:09 PM
AndyF Offline
AndyF  Offline
They'll work with an evac system, just not as well as they would work with a pump.
Re: Best ring pack for pan evac equiped race bb? [Re: gregsdart] #2834062
10/17/20 10:07 PM
10/17/20 10:07 PM
I bought and used a .043,.043 with a 1/8 inch low tension oil ring for my 518 C.I. 400 block current bracket motor with a vacuum pump up
I'm not sure what current trick racing sizes are available now as I built that motor two winters ago shruggy
I like it a lot, runs good , makes a lot of power boogie
Re: Best ring pack for pan evac equiped race bb? [Re: gregsdart] #2834153
10/18/20 10:20 AM
10/18/20 10:20 AM
Minnesota
R3 Racing Offline
R3 Racing  Offline
Minnesota
Check you PMs.
Re: Best ring pack for pan evac equiped race bb? [Re: R3 Racing] #2835688
10/21/20 03:33 PM
10/21/20 03:33 PM
On the parachute mount
N
n20mstr Online content
n20mstr  Online Content
N
Just food for thought here. My son rebuilt a magnum 360. Ball honed , and a standard forged piston. Im pretty sure 1/16 rings. Your standard moly type off the shelf piston/ring.
He put an evac system on it, and a vac gauge on the valve cover. Of course it produced little to no vacum. I told him get rid of all the rubber gromets etc. He fabbed some alum pucks with the centers tapped for 3/8 pipe. He welded these onto the valve covers. Got some -10 AN fittings and hose and plumbed it to the headers. Then he put one with a check valve to a breather tank so if there was positive pressure it could vent. This AN setup produces some vacum ! At idle the gauge just comes off "0" . At 55mph on the freeway it has 3" of vac. At the track depending on the air it produces 3-4" of vacum at the stripe. I was impressed. The key is sealing up the connections at the valve covers , as much as you can
....BAD A$$ STREET CAR.....
Re: Best ring pack for pan evac equiped race bb? [Re: n20mstr] #2835693
10/21/20 03:48 PM
10/21/20 03:48 PM
Great to know! Thanks.
Re: Best ring pack for pan evac equiped race bb? [Re: gregsdart] #2835980
10/22/20 09:28 AM
10/22/20 09:28 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Call or email Total Seal.
They strongly encourage folks to call before they start a project.
https://www.totalseal.com/
Re: Best ring pack for pan evac equiped race bb? [Re: 340Cuda] #2835986
10/22/20 09:33 AM
10/22/20 09:33 AM
an8sec70cuda Offline
This last time I went w/ a .043" top, 1/16" 2nd and 3/16" oil ring on my new pistons. New slugs and fresh bores sure seems to have made this old motor run better.
Fresh motor check-out/break-in pass earlier this year it ran 9.73 at 139.6 mph w/ only a 1.43 sixty foot. This was all motor w/ a real tight nitrous converter and 3.54 gear.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Best ring pack for pan evac equiped race bb? [Re: gregsdart] #2844325
11/10/20 12:07 AM
11/10/20 12:07 AM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
Whose Big Block pistons You use for the 1/1/3mm ring package?
Re: Best ring pack for pan evac equiped race bb? [Re: Dduster] #2845090
11/11/20 09:23 PM
11/11/20 09:23 PM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
Same Question??: "Whose Big Block pistons You use for the 1/1/3mm ring package?"
Re: Best ring pack for pan evac equiped race bb? [Re: Dduster] #2845107
11/11/20 09:48 PM
11/11/20 09:48 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I used Diamond.
Doug
Re: Best ring pack for pan evac equiped race bb? [Re: Dduster] #2845148
11/11/20 11:35 PM
11/11/20 11:35 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
i used .9mm .9mm 3mm the pistons are ross
Joe
Without Data, you’re just another guy with an opinion.
Re: Best ring pack for pan evac equiped race bb? [Re: sr4440] #2845403
11/12/20 03:28 PM
11/12/20 03:28 PM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
Thank You for the information.
Re: Best ring pack for pan evac equiped race bb? [Re: Dduster] #2845451
11/12/20 05:05 PM
11/12/20 05:05 PM
America
WedgeFED Offline
WedgeFED  Offline
America
ICON will also do any ring pack you want.
