727 tips and tricks #2832756
10/14/20 03:27 PM
10/14/20 03:27 PM
Home
SRT6776 Offline OP
I hate internal combustion engines!
SRT6776  Offline OP
Home
Re: 727 tips and tricks [Re: SRT6776] #2832835
10/14/20 08:04 PM
10/14/20 08:04 PM
Wi
Scat Offline
Scat  Offline
Wi
Reverse Servo should be swapped for a single bullet piece, the 2 piece stock design is known to fail easy with added pressure.
6 Direct clutches don't always make full engagement on the input shaft using the forward clutch plate. Had a few diesels chew the input up from them not engaging enough. You can also use the 48re plate instead of using the forward pressure plate as well with the thinner clutch's and steels.
Also everyone what I've ever done with power i replace the front drum spring retainer for a TCS one.
73 Duster 340 a518 6pack
Re: 727 tips and tricks [Re: Scat] #2832966
10/15/20 11:01 AM
10/15/20 11:01 AM
NC
440Jim Offline
440Jim  Offline
NC
I like the aftermarket heavy duty front drum spring retainer also.
For the rear servo, I have used both the "billet" 1-piece units, with heavy duty (thicker) spring retainer;
and also the "billet" Sonnax type replacement piston and still used the factory inner part, but shimmed the spring solid.
Link to Sonnax web site
Part No. Application OE Part No. O.D.
22912C 47-48RE '97-Later 52118745 2.46"
22912B 47RE/RH '94–'96 4531229 2.46"
22912 46RE/RH, A727 2801281 2.80"
Re: 727 tips and tricks [Re: 440Jim] #2832967
10/15/20 11:05 AM
10/15/20 11:05 AM
NC
440Jim Offline
440Jim  Offline
NC
CRT has a kit with the heavy duty front spring retainer and new springs.
https://www.coperacingtrans.com/?product=727-front-drum-spring-retainer-with-springs-2
Re: 727 tips and tricks [Re: 440Jim] #2832996
10/15/20 12:24 PM
10/15/20 12:24 PM
NC
440Jim Offline
440Jim  Offline
NC
The heavy duty front band strut is also an inexpensive upgrade.
There are many sources and a couple styles available.
Re: 727 tips and tricks [Re: 440Jim] #2833000
10/15/20 12:29 PM
10/15/20 12:29 PM
NC
440Jim Offline
440Jim  Offline
NC
I first saw this tip from a B&M instruction set.
Improves fluid flow to the front clutch pack, for better lubrication and cooling in lower gears.
Re: 727 tips and tricks [Re: 440Jim] #2833010
10/15/20 12:47 PM
10/15/20 12:47 PM
NC
440Jim Offline
440Jim  Offline
NC
In the original poster's video, they mention shimming the front band servo solid (later style with large pin and only 1 spring).
This is a pic of one I did, you can see the dimensions of the shim needed (yellow arrow).
Re: 727 tips and tricks [Re: 440Jim] #2833057
10/15/20 02:42 PM
10/15/20 02:42 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Wonder why a billet drum wasn’t included. Got to have some safety.
Re: 727 tips and tricks [Re: 440Jim] #2833073
10/15/20 03:43 PM
10/15/20 03:43 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I've always been skeptical of that mod, lets more fluid in but nowhere for it to go unless the periphery of the drum is drilled.
Re: 727 tips and tricks [Re: John_Kunkel] #2833280
10/16/20 07:44 AM
10/16/20 07:44 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Could always take that up a notch.....
Re: 727 tips and tricks [Re: J_BODY] #2833292
10/16/20 08:23 AM
10/16/20 08:23 AM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
Now we are talking
So what power level has that bit of swiss cheese handled?
Which bands?
Re: 727 tips and tricks [Re: John_Kunkel] #2833305
10/16/20 08:55 AM
10/16/20 08:55 AM
pennsylvania
poboyengineering Offline
pennsylvania
What year was the split between the early and late model trans he is talking about in the beginning?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: 727 tips and tricks [Re: poboyengineering] #2833417
10/16/20 11:52 AM
10/16/20 11:52 AM
moparx Online content
moparx  Online Content
the three pin NSS started in '69. the single pin NSS was 66-68, not counting the pushbutton 62-65 transmissions, which also had the single pin NSS. i'm not sure that the pushbutton NSS was even the same as the 66-68 switch. maybe JK can clarify on that.
beer
Re: 727 tips and tricks [Re: moparx] #2833492
10/16/20 02:24 PM
10/16/20 02:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Actually, the 3-prong NSS was introduced late in '68 (5-15-68). '62-'64 PB switch on left, '64-'68 2nd from left.
Re: 727 tips and tricks [Re: John_Kunkel] #2833907
10/17/20 03:03 PM
10/17/20 03:03 PM
JK, i knew you would know for sure ! up
beer
Re: 727 tips and tricks [Re: Alchemi] #2834409
10/18/20 11:55 PM
10/18/20 11:55 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Originally Posted by Alchemi
Now we are talking
Which bands?
Went low tens in a 3400lb car.... it was in a trans that I bought. It was also machined on the back side and quite light. I upgraded to a billet drum as every car that hits the track should have smile
