Wife called, Van wont start FIXED #283260
04/10/09 08:38 AM
04/10/09 08:38 AM
BROOK PARK, OH
WILD BILL Offline OP
BROOK PARK, OH
It's a 91 B 250 318 TBI. It cranks but has no spark and no fuel. I have not yet put my noid light on it but I would imagine that I would see no pulse if I had. The last time this happened it was the shutdown relay and the time before that it was the pick up in the dist. I replaced the pick up and still no start.
I can feel the relay click and feel the vibration difference in the tank when the pump turns on and off.
I also put a test light on the coil and get nothing there.
Any ideas.
Re: Wife called, Van wont start [Re: WILD BILL] #283261
04/10/09 10:18 AM
04/10/09 10:18 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Sounds like you are on the right path. Just follow the factory No Start diagnostics start to finish.
Re: Wife called, Van wont start [Re: RodStRace] #283262
04/10/09 10:57 AM
04/10/09 10:57 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I had quite a few coils go bad on those.More than I care to mention.Rocky
Chrysler Firepower
Re: Wife called, Van wont start [Re: therocks] #283263
04/10/09 11:40 AM
04/10/09 11:40 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Thought it was the magnums with the frequent coil failures...
Re: Wife called, Van wont start [Re: therocks] #283264
04/10/09 02:05 PM
04/10/09 02:05 PM
BROOK PARK, OH
BROOK PARK, OH
I thought coil to but I don't think that would kill the signal to the injectos and I would be seeing some fuel spraying.
I don't think it's getting an input signal to either the coil or the injectors.
Re: Wife called, Van wont start [Re: WILD BILL] #283265
04/10/09 02:23 PM
04/10/09 02:23 PM
P
Paul_Fancsali Offline
P
Having had fleet of them over the years change the coil even if that not the problem if its original it will be sooner or later
Re: Wife called, Van wont start [Re: buildanother] #283266
04/10/09 08:35 PM
04/10/09 08:35 PM
N
NITROUSN Offline
NITROUSN  Offline
N
The modular style that mounted up in front of the motor were common for failure.
My bets are on the distributor pickup. No signal equals no spart or fuel pump running.
Re: Wife called, Van wont start [Re: NITROUSN] #283267
04/10/09 09:01 PM
04/10/09 09:01 PM
BROOK PARK, OH
BROOK PARK, OH
That was my first thought. Put in a new one and no luck.
Re: Wife called, Van wont start [Re: WILD BILL] #283268
04/11/09 03:05 PM
04/11/09 03:05 PM
BROOK PARK, OH
BROOK PARK, OH
Fixed
Auto shut down relay again. And it wasn't even that old
