440 dist. drive gear #283144
04/09/09 10:45 PM
04/09/09 10:45 PM
New York
K
Ken25 Offline OP
Ken25  Offline OP
K
New York
i was wondering how much play in the dist. shaft. how is the gear removed and where would you get a new one? thanks
Re: 440 dist. drive gear [Re: Ken25] #283145
04/09/09 10:58 PM
04/09/09 10:58 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
Usaually just bend a coat hanger wire into 3-4 prongs / hooks, and lift straight up. The shaft is long enough so with a handle on the situation it won't fall in. A extendable magnet may help as a safety.
Re: 440 dist. drive gear [Re: Ken25] #283146
04/09/09 11:22 PM
04/09/09 11:22 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Just put a big screwdriver into the slot and twist, it will come right up. Then hook it and pull up, magnet, etc. - pretty easy and obvious.
If you're a newbie, you might want to note the orientation before removing (and don't crank the engine while removed.)
The Mopar Performance one is the way to go, it is tapered and pinned. A real engine saver!
If the oil pump is installed, there should be no perceptible slop in the bushing. if you change the bushing (in the block) it must be burnished to size with the factory tool.
Rick
Re: 440 dist. drive gear [Re: Rick_Ehrenberg] #283147
04/09/09 11:29 PM
04/09/09 11:29 PM
New York
K
Ken25 Offline OP
Ken25  Offline OP
K
New York
the slop i have is rotating the dist. shaft. turning back and forth it acts like a worn gear.i could tell its not play in the advance.the rotor tip moves almost 3/16 from one side to the other.
Re: 440 dist. drive gear [Re: Ken25] #283148
04/09/09 11:42 PM
04/09/09 11:42 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
That sounds more like the distributor bushing. yeah if it's not freed up twist a screwdriver to pop it, or ride the bumps to the correct timming gear placement.
Do the gear teeth look marred ?
Re: 440 dist. drive gear [Re: mark7171] #283149
04/10/09 12:09 AM
04/10/09 12:09 AM
New York
K
Ken25 Offline OP
Ken25  Offline OP
K
New York
i can't realy tell how the teeth look till i get the gear out.the bushing in the dist. is pretty good.it acts like the teeth are worn. i'll pull the gear out and see.thanks
Re: 440 dist. drive gear [Re: Ken25] #283150
04/10/09 09:42 AM
04/10/09 09:42 AM
that's the tang on the end of the dist being smaller than the slot on the top of the intermediate shaft/gear. I'd put a 1/2" collar on the shaft. when I did my timing marks stayed rock steady whereas before they were al over the place. PS what did the ign problem end up being the other day?
