PST strut rod bushings--which way do washers go? #2272131
03/19/17 02:06 AM
03/19/17 02:06 AM
Seattle, WA
3
375inStroke Offline OP
Special needs person
3
Seattle, WA
1969 Charger, does the concave side go towards the bushing like original, or face away like Moog improved? These are all I can find right now in my myriad of new parts acquired for three cars, and I'd just like to get this thing back on the road. Some people say they are junk. With the sleeve they supply, the bushings will compress .3". That seems like a lot for how hard these bushings are. I see how people are complaining about them splitting in no time. Others say they have over 10,000 miles on them without problems. Would Moog be better, or just wait and see if they last? Either way, I need help.
Re: PST strut rod bushings--which way do washers go? [Re: 375inStroke] #2272161
03/19/17 04:27 AM
03/19/17 04:27 AM
I would think you would want the concave side facing the bushing for the most contact area. Any pics? which ones do you have right now?
Re: PST strut rod bushings--which way do washers go? [Re: RapidRobert] #2272189
03/19/17 10:02 AM
03/19/17 10:02 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
iagree
just did all this last year on a 69 RR. the 'cup' goes towards the bushing.
Re: PST strut rod bushings--which way do washers go? [Re: mikemee1331] #2272304
03/19/17 01:08 PM
03/19/17 01:08 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
iagree
Agreed, to the OP if you want to avoid failure, install them with the lube supplied, don't use any petroleum based products on Poly suspension bushings, tighten components at loaded ride height
Re: PST strut rod bushings--which way do washers go? [Re: 375inStroke] #2272533
03/19/17 07:55 PM
03/19/17 07:55 PM
Seattle, WA
3
3
Seattle, WA
This is what I have. Kit did not come with washers, instructions, or grease. I have silicone brake grease, and silicone electrical grease if I'm suppose to use something like that as someone suggested.
The sleeve included is .3" shorter than the free length of the stacked bushings. I don't see how these can compress that much without splitting in short order. I mocked up the lower control arm and strut rod on the K-frame, and the shoulder of the strut rod sits 7/8" behind the K-frame. This is just slightly less than the thickness of what the original bushing, which is still intact, and washer has set to. The thickness of one bushing and washer is 1-1/8", so if I cut 1/4" off the rear bushing, it will allow the lower control arm to sit where it wants to be without any preload pushing it back, stressing the LCA bushing, and reducing caster. There is an early Barracuda auto-xer who cut 1/4" off the back of his poly strut rod bushings with success.
Hot Rod magazine installed a PST kit on a Dart, and this is what they did. You can see the washer says "THIS SIDE TO RUBBER" on the convex side:
I found these PST instructions on the internet, and they show only the rear washer concave out, and the front concave in:
Here are the instructions from a Moog A-body kit I have. Two styles have the concave washers both outward, which without these instructions, one would believe is backwards, and is opposite of what was originally installed, and how the FSM shows, but these bushings are different than original. They are the "improved design," which they charge four times the price for. This kit uses the style on the lower right, with one cup in, and one out like the PST instructions above:
The bigger washer says "THIS SIDE TO FRONT" on the convex side, so the concave is to the bushing, and the smaller one says "THIS SIDE TO RUBBER" on the convex side, so the concave is away from the rear bushing.
Now my PST kit didn't come with washers, so I only have the original washers, which may be shaped differently from the aftermarket ones that go backwards. Who would have thought a strut rod bushing could be so complicated?
Re: PST strut rod bushings--which way do washers go? [Re: 375inStroke] #2272555
03/19/17 09:09 PM
03/19/17 09:09 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i can't speak about an A-body so i don't know what is correct. my kit was Energy Suspension and was bushings only too. i put my washers on the exact same way the came off, cup facing into the bushing. the kit also came with a jar of silicone grease. in tour case i would use the brake grease. it's only to make them slide or press on easier and to help eliminate any of the squeaks everyone use to complain about.
Re: PST strut rod bushings--which way do washers go? [Re: 375inStroke] #2273728
03/21/17 03:49 PM
03/21/17 03:49 PM
Seattle, WA
3
3
Seattle, WA
I could squeeze them about .1" in a vise before experiencing hard resistance. They were .28" thicker than the sleeve, so I shaved .18" off the pointy end of the rear bushings. Torqued in place, with both washers facing concave side towards the bushing, it puts the LCA right where it should be on the K-frame without any preload fore or aft.
Re: PST strut rod bushings--which way do washers go? [Re: 375inStroke] #2273761
03/21/17 04:32 PM
03/21/17 04:32 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
in the words of Ron Swanson - "cool beans!" up
Re: PST strut rod bushings--which way do washers go? [Re: mikemee1331] #2276522
03/26/17 03:01 PM
03/26/17 03:01 PM
Wisconsin
wkroncke17 Offline
wkroncke17  Offline
Wisconsin
Found this in my '72 chassis book.
Not sure if Stock is different than poly??
About to do these myself so it has me wondering.
Re: PST strut rod bushings--which way do washers go? [Re: wkroncke17] #2276578
03/26/17 04:16 PM
03/26/17 04:16 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
poly follows the same assembly if that was your question.
some of the confusion was caused by referencing an A-body assembly for a B-body and a size variance.
Re: PST strut rod bushings--which way do washers go? [Re: mikemee1331] #2830541
10/08/20 08:21 PM
10/08/20 08:21 PM
Seattle, WA
3
3
Seattle, WA
Update: Well that was a disaster. Think I'll use rubber for now on.
Re: PST strut rod bushings--which way do washers go? [Re: 375inStroke] #2830551
10/08/20 08:42 PM
10/08/20 08:42 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
Someof that crack looks rusty, probably going to fail regardless, just happened quicker is all.
Re: PST strut rod bushings--which way do washers go? [Re: Sniper] #2830628
10/09/20 03:10 AM
10/09/20 03:10 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
That looks like impact damage from repeatedly hitting potholes.
Re: PST strut rod bushings--which way do washers go? [Re: Kern Dog] #2830697
10/09/20 10:49 AM
10/09/20 10:49 AM
Seattle, WA
3
3
Seattle, WA
Well, these streets do suck.
