Re: Grr! Split cylinder, head damage! [Re: gregsdart] #2829887
10/07/20 03:31 PM
10/07/20 03:31 PM
Originally Posted by gregsdart
Iron megablock.
I don' t think it is going to be cheapšŸ˜¢we will see.
Is that a end cylinder or not?
I have had a bunch of stock blocks sleeved for different reasons, I ended up learning that you can sleeve a block like yours two ways, pressed in with a press in interference fit from .0025 to .0040 or chilling the sleeve in dry ice and heating the block up enough to allow the cold sleeve drop in or be push in by hand with a .00010 to .0010 interference fit. The pressed in with the tighter fit can and may affect the cylinder wall shape on the cylinders beside it scope which may need a lot of honing to make them round again scope. I now plan on installing all four sleeves on the side needing the sleeve unless I'm going to have it bored and honed to the next over size and buy new pistons twocents
Either way make sure and use a good sleeve sealer on the sleeves that go in all the cylinder that have cracks in them up wrench scope
Re: Grr! Split cylinder, head damage! [Re: Cab_Burge] #2830043
10/07/20 05:16 PM
10/07/20 05:16 PM
gregsdart Offline OP
Thanks Cab. I have decided that it makes sense to go to a new block. I have always wanted to go aluminum and i am using this as my excuse. I assume there is some value in the megablock since it can be sleeved.
I talked to Todd at Marsh performance and have my name on a World aluminum block that is on its way to Todd.
Re: Grr! Split cylinder, head damage! [Re: gregsdart] #2830137
10/07/20 08:42 PM
10/07/20 08:42 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Sonic the cylinder. My bet its thin. It split, let water in that cylinder and coughed the gasket due to rough deck surface. Could have been worse. Hydro locked and taken out the rod and block.
Doug
Re: Grr! Split cylinder, head damage! [Re: moparacer] #2830166
10/07/20 10:20 PM
10/07/20 10:20 PM
Again, there is no corrosion in the bores. This motor has never been shut down for the day until it was run for several seconds on gasoline and still very warm, like above 180. It had dyno pulls on it and eight passes total after being honed and reringed. What may look like corosion is a depression you can feel, it is that deep. The cylinderwall colapsed.
Re: Grr! Split cylinder, head damage! [Re: gregsdart] #2830451
10/08/20 04:06 PM
10/08/20 04:06 PM
moparx Offline
moparx  Offline
as to the tight dowel register fit, i think that would have been caught during assembly ? shruggy
beer
Re: Grr! Split cylinder, head damage! [Re: 440Jim] #2830480
10/08/20 05:22 PM
10/08/20 05:22 PM
PA
moparacer Offline
moparacer  Offline
PA
Originally Posted by 440Jim
Originally Posted by moparacer
That is from methanol laying in the cylinders.
I have seen that enough times over the years.
The only way I ever got that to stop is to put a gas primer on my car and run it on gas to clean the cylinders out at the end of the day.
Does running top end lube in the methanol help at all?
I see Greg did use a gas primer system, including at the end of the day to clear the engine.
I dont think lube makes much of a difference Jim.
They are more like stains that look worse than they actually are.
I found that just shutting the alky off and running on the primer isn't enough. Seems like fuel will still be left in the barrel valve, lines and nozzles and drain and drip into the engine. After I have run mine for a few minutes I blip the throttle several times before I shut it off.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
