Fuel pressure drop #2829122
10/05/20 10:51 PM
10/05/20 10:51 PM
WV
WV Runner Offline OP
WV
Fuel pressure is dropping at the track and I was only running 1/8mile. Still a fresh build, it’s a 493 with a pro form 850. Has a Holley black pump dead headed, 3/8 feed line, with a 3/8 sending unit out of the stock tank. I set the regulator to 7psi and it’s down to 3 while I’m still in second gear. Pump is ground on the frame, seems like a good ground, power out of a fuse box I installed then to a 20amp toggle switch then runs to pump. What am I missing?
Re: Fuel pressure drop [Re: WV Runner] #2829138
10/05/20 11:25 PM
10/05/20 11:25 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Volume ?
Re: Fuel pressure drop [Re: WV Runner] #2829162
10/06/20 02:10 AM
10/06/20 02:10 AM
Boise
Moparteacher Offline
Boise
Disconnect fuel line from carb. Run hose into 5 gallon pail. Time one minute and measure fuel volume. Compare to requirements for hp and et.
If volume is low measure voltage drop to pump on positive side and then negative side at running voltage.
If you want to get really into it. you could get an oscilloscope and current ramp the pump, acquire frequency and calculate rpm, and pattern integrity. This is how we teach fuel pump diagnoses on non-race cars.
Re: Fuel pressure drop [Re: Moparteacher] #2829185
10/06/20 08:24 AM
10/06/20 08:24 AM
WV
WV
I’ll check volume tonight, I don’t know what it’s requirements are. Being I have a stock tank, could it be not venting enough?
Re: Fuel pressure drop [Re: WV Runner] #2829206
10/06/20 09:42 AM
10/06/20 09:42 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
It doesn't take a whole lot of opening to vent , but that is certainly a possibility.
After a pass , remove the fuel cap and if you hear any pressure ( vacuum ) release , that is a problem.
Re: Fuel pressure drop [Re: tubtar] #2829268
10/06/20 12:22 PM
10/06/20 12:22 PM
WV
WV
Something else I just thought about, fuel slosh in the tank? Stock tank has no baffles. Anyone ever run one?
Re: Fuel pressure drop [Re: WV Runner] #2829271
10/06/20 12:32 PM
10/06/20 12:32 PM
an8sec70cuda Offline
I use a stock tank w/ a sump welded on...no issues w/ fuel pressure.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Fuel pressure drop [Re: WV Runner] #2829272
10/06/20 12:35 PM
10/06/20 12:35 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
1/2 line minimum......
Re: Fuel pressure drop [Re: Thumperdart] #2829279
10/06/20 12:56 PM
10/06/20 12:56 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
ON STOCK tanks, i always drill a hole on the bottom towards the back, and thread in a brass bushing. (3/8 internal threads whatever external) I then solder this in. Screw in a nice AN fitting 3/8 X -8 or etc, Use that as the feed your your pump. Works very well . Your fighting a lot of gravity with the stock pick up and the faster you go, the harder it is to pull the fuel up that pickup.
....BAD A$$ STREET CAR.....
Re: Fuel pressure drop [Re: an8sec70cuda] #2829286
10/06/20 01:05 PM
10/06/20 01:05 PM
WV
WV
What do you mean by sump?
Re: Fuel pressure drop [Re: WV Runner] #2829288
10/06/20 01:14 PM
10/06/20 01:14 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Is this a replacement 3/8 seding unit and pick up? If so did you retail the sock that covers the pick up. If so this could be an issue. We had problems with higher volume pumps trying to suck the sock into the line.
Ok
Re: Fuel pressure drop [Re: cudatom] #2829304
10/06/20 01:50 PM
10/06/20 01:50 PM
WV
WV
Yes it’s a replacement, what you mean by retail? All opened it and installed it, didn’t do anything honestly
Re: Fuel pressure drop [Re: WV Runner] #2829369
10/06/20 04:35 PM
10/06/20 04:35 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Sump.
I drill 1 " holes with the hole saw inside the perimeter of the sump , and weld it on the tank.
This acts to keep fuel at the pick up point under deceleration.......sort of a slosh baffle.
Re: Fuel pressure drop [Re: WV Runner] #2829390
10/06/20 05:05 PM
10/06/20 05:05 PM
What size I.D. is your current fuel line and gas tank pickup ?
Fuel gremlins come in many forms rant whiney
The smallest hole in the system is the biggest restrictor to fuel flow work scope
You may want to test that system another way at the track, jet the carb up one size at a time to see if you have enough fuel volume to that carb to slow the MPH down scope wrench If you can slow it down by jetting it richer you have enough fuel volume delivery for your current power up
If not fix it wrench grin
Re: Fuel pressure drop [Re: WV Runner] #2829447
10/06/20 06:03 PM
10/06/20 06:03 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
if your battery is in the trunk i would use the toggle switch to a a relay in the trunk to the fuel pump, i wouldn't run the pump off a toggle switch
Re: Fuel pressure drop [Re: WV Runner] #2829460
10/06/20 06:27 PM
10/06/20 06:27 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Sorry it should have said did you retain the sock on the pick up. My fat thumbs don't do well on phone keyboards.
Ok
Re: Fuel pressure drop [Re: cudatom] #2829732
10/07/20 11:24 AM
10/07/20 11:24 AM
Sump pics
CHIP
Re: Fuel pressure drop [Re: an8sec70cuda] #2829737
10/07/20 11:28 AM
10/07/20 11:28 AM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
Now that’s just mean!
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Fuel pressure drop [Re: WV Runner] #2830066
10/07/20 06:11 PM
10/07/20 06:11 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Sometimes setting the pressure high at idle results in larger drop in pressure.
It depends on how the regulator is designed and the fuel pump pressure and flow rate (gals/min) relationship.
A deadheaded pump is delivering close to zero gallons per minute at idle.
It is going to depend on the regulator pressure and the flows and pressures it will see (ie the the pump).
We took a look at a couple different regulators, and then the effect of control pressures and flow rates in this thread.
https://www.forabodiesonly.com/mopa...b-stumble.437541/page-20#post-1972625252
(read down from that post for pump output volume and cudafever's tests)
You can probably test in a similar manner, but start with the pump data from the manufacturer.
There's some basic rules of thumb for fuel consumption, and you can also look at engine dyno data for similar engines.
