Re: Fuel pressure drop
[Re: WV Runner]
#2829162
10/06/20 02:10 AM
10/06/20 02:10 AM
Posts: 609 Boise
Moparteacher
Boise
Disconnect fuel line from carb. Run hose into 5 gallon pail. Time one minute and measure fuel volume. Compare to requirements for hp and et.
If volume is low measure voltage drop to pump on positive side and then negative side at running voltage.
If you want to get really into it. you could get an oscilloscope and current ramp the pump, acquire frequency and calculate rpm, and pattern integrity. This is how we teach fuel pump diagnoses on non-race cars.
[Re: WV Runner]
#2829271
10/06/20 12:32 PM
10/06/20 12:32 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
I use a stock tank w/ a sump welded on...no issues w/ fuel pressure.
[Re: Thumperdart]
#2829279
10/06/20 12:56 PM
10/06/20 12:56 PM
Posts: 4,682 On the parachute mount
n20mstr
ON STOCK tanks, i always drill a hole on the bottom towards the back, and thread in a brass bushing. (3/8 internal threads whatever external) I then solder this in. Screw in a nice AN fitting 3/8 X -8 or etc, Use that as the feed your your pump. Works very well . Your fighting a lot of gravity with the stock pick up and the faster you go, the harder it is to pull the fuel up that pickup.
....BAD A$$ STREET CAR.....
[Re: an8sec70cuda]
#2829286
10/06/20 01:05 PM
10/06/20 01:05 PM
Posts: 65 WV
WV Runner
WV
I use a stock tank w/ a sump welded on...no issues w/ fuel pressure. What do you mean by sump?
[Re: WV Runner]
#2829288
10/06/20 01:14 PM
10/06/20 01:14 PM
Posts: 1,099 Massillon, Ohio
cudatom
Massillon, Ohio
Is this a replacement 3/8 seding unit and pick up? If so did you retail the sock that covers the pick up. If so this could be an issue. We had problems with higher volume pumps trying to suck the sock into the line.
Ok
[Re: cudatom]
#2829304
10/06/20 01:50 PM
10/06/20 01:50 PM
Posts: 65 WV
WV Runner
WV
Is this a replacement 3/8 seding unit and pick up? If so did you retail the sock that covers the pick up. If so this could be an issue. We had problems with higher volume pumps trying to suck the sock into the line. Yes it’s a replacement, what you mean by retail? All opened it and installed it, didn’t do anything honestly
[Re: WV Runner]
#2829460
10/06/20 06:27 PM
10/06/20 06:27 PM
cudatom
Massillon, Ohio
Is this a replacement 3/8 seding unit and pick up? If so did you retail the sock that covers the pick up. If so this could be an issue. We had problems with higher volume pumps trying to suck the sock into the line. Yes it’s a replacement, what you mean by retail? All opened it and installed it, didn’t do anything honestly Sorry it should have said did you retain the sock on the pick up. My fat thumbs don't do well on phone keyboards.
Ok
[Re: cudatom]
#2829732
10/07/20 11:24 AM
10/07/20 11:24 AM
an8sec70cuda
[Re: WV Runner]
#2830066
10/07/20 06:11 PM
10/07/20 06:11 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Sometimes setting the pressure high at idle results in larger drop in pressure. It depends on how the regulator is designed and the fuel pump pressure and flow rate (gals/min) relationship. A deadheaded pump is delivering close to zero gallons per minute at idle. It is going to depend on the regulator pressure and the flows and pressures it will see (ie the the pump). We took a look at a couple different regulators, and then the effect of control pressures and flow rates in this thread. https://www.forabodiesonly.com/mopa...b-stumble.437541/page-20#post-1972625252(read down from that post for pump output volume and cudafever's tests) You can probably test in a similar manner, but start with the pump data from the manufacturer. There's some basic rules of thumb for fuel consumption, and you can also look at engine dyno data for similar engines.
