trick flow 270 heads #2825577
09/27/20 10:45 AM
09/27/20 10:45 AM
ma.
duspan Offline OP
duspan  Offline OP
ma.
how fast are you running with the trick flow 270 heads?
thanks
Re: trick flow 270 heads [Re: duspan] #2825601
09/27/20 11:53 AM
09/27/20 11:53 AM
AndyF Offline
AndyF  Offline
270 heads will make 700 to 800 hp out of the box so it just depends how heavy the car is and how well it hooks up. I have one customer who is running 9.70 in a 3500 lb B body with 270 heads on a 505 shortblock. No reason they couldn't go faster in a lighter car.
Re: trick flow 270 heads [Re: AndyF] #2825737
09/27/20 05:42 PM
09/27/20 05:42 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
been 10.20s @ 3780lbs with a flat tappet cam , pump gas , full street exhaust to diff .505ci
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: trick flow 270 heads [Re: tex013] #2826125
09/28/20 04:09 PM
09/28/20 04:09 PM
ma.
duspan Offline OP
duspan  Offline OP
ma.
can you tell me what camshaft specs you are running with these heads?
Re: trick flow 270 heads [Re: duspan] #2826167
09/28/20 05:16 PM
09/28/20 05:16 PM
AndyF Offline
AndyF  Offline
Here is one article where I used 270 heads on a pump gas 470 low deck engine that made 750 hp. This engine had a bunch of high dollar parts in it that the average bracket guy isn't going to want to duplicate, but it still shows the potential of the heads.
https://www.hotrod.com/articles/dyno-tested-dual-conical-valve-springs/
Re: trick flow 270 heads [Re: duspan] #2826180
09/28/20 05:39 PM
09/28/20 05:39 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
272@050 single pattern , 310 advertised
108
.408 lobe . 0.012 lash
has a slower ramp for street durability . It is a custom ground from Crow Cams here in Aust .
i do have a 6000 vert , 4.10 gears and 30"radial slicks
Tex
New best MPH 130.32
Re: trick flow 270 heads [Re: tex013] #2827019
09/30/20 05:59 PM
09/30/20 05:59 PM
ma.
duspan Offline OP
duspan  Offline OP
ma.
what are the best spark plugs to use with these heads?
Re: trick flow 270 heads [Re: duspan] #2827021
09/30/20 06:05 PM
09/30/20 06:05 PM
It depends on which fuel your using, the compression ratio, type of use, race or street or and so on shruggy
E85 fuel doesn't like hot plugs and a lean mix on pump gas or race gas like them colder shruggy
Re: trick flow 270 heads [Re: duspan] #2827098
09/30/20 09:10 PM
09/30/20 09:10 PM
AndyF Offline
AndyF  Offline
The ones that are the correct heat range for the engine.
Re: trick flow 270 heads [Re: AndyF] #2827375
10/01/20 01:19 PM
10/01/20 01:19 PM
ma.
duspan Offline OP
duspan  Offline OP
ma.
with a 11.0 compression pump gas, on the street and a mix at c12 at the track?
Re: trick flow 270 heads [Re: duspan] #2827481
10/01/20 04:50 PM
10/01/20 04:50 PM
AndyF Offline
AndyF  Offline
I'd probably use a NGK with a 7 heat range but I'd call NGK tech line first. They have a lot of plugs that will fit that application so it kind of depends on how much money you want to spend. A basic plug would be this one: https://www.summitracing.com/parts/ngk-4644
Re: trick flow 270 heads [Re: duspan] #2827502
10/01/20 05:38 PM
10/01/20 05:38 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
i use NGK BKR6E
11.0:1 98 pump gas . Does not get any race or additive
Tex
New best MPH 130.32
Re: trick flow 270 heads [Re: duspan] #2827538
10/01/20 07:01 PM
10/01/20 07:01 PM
On your deal I would use either Autolite race plugs #3911 or the colder #3910 scope twocents
Or the street resistor plugs like Autolite # 3922 or 3924 scope
Re: trick flow 270 heads [Re: tex013] #2827598
10/01/20 09:10 PM
10/01/20 09:10 PM
AndyF Offline
AndyF  Offline
Originally Posted by tex013
i use NGK BKR6E
Tex
Call the NGK tech line and see what they recommend for your engine. I'm pretty sure they'll recommend a 7 heat range rather than the 6 that you are using.
Re: trick flow 270 heads [Re: AndyF] #2827692
10/02/20 05:23 AM
10/02/20 05:23 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Andy ,
Not sure there is a ngk help line down here .as a daily driver the -6 is fine especially with biggish cam and 4500 carb .
Dont forget we dont get oxygenated fuel here . Our octane probably equeals your 95/96 ?
I actually talked to ICE ignition here a few years ago and they recommended a -6 .
I have not had pinging or any sign of preignition . No matter weather or engine temp , long highway or city driving .
Its a bit like beer , got to try it to see if you like it
Tex
New best MPH 130.32
Re: trick flow 270 heads [Re: tex013] #2827907
10/02/20 02:23 PM
10/02/20 02:23 PM
moparx Offline
moparx  Offline
Tex
i like the way you think. up
beer
Re: trick flow 270 heads [Re: moparx] #2828084
10/02/20 09:04 PM
10/02/20 09:04 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
You can cross the plug into the Ngk race series as well and go pretty cold.
Re: trick flow 270 heads [Re: Uberpube] #2829441
10/06/20 05:59 PM
10/06/20 05:59 PM
ma.
duspan Offline OP
duspan  Offline OP
ma.
i want to thank you guys for the help
