Re: trick flow 270 heads
[Re: AndyF]
#2825737
09/27/20 05:42 PM
09/27/20 05:42 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
been 10.20s @ 3780lbs with a flat tappet cam , pump gas , full street exhaust to diff .505ci
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: duspan]
#2826180
09/28/20 05:39 PM
09/28/20 05:39 PM
tex013
Sydney,Australia
can you tell me what camshaft specs you are running with these heads? 272@050 single pattern , 310 advertised 108 .408 lobe . 0.012 lash has a slower ramp for street durability . It is a custom ground from Crow Cams here in Aust . i do have a 6000 vert , 4.10 gears and 30"radial slicks Tex
[Re: tex013]
#2827019
09/30/20 05:59 PM
09/30/20 05:59 PM
Posts: 100 ma.
duspan
ma.
what are the best spark plugs to use with these heads?
[Re: duspan]
#2827021
09/30/20 06:05 PM
09/30/20 06:05 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
what are the best spark plugs to use with these heads? It depends on which fuel your using, the compression ratio, type of use, race or street or and so on E85 fuel doesn't like hot plugs and a lean mix on pump gas or race gas like them colder
[Re: duspan]
#2827098
09/30/20 09:10 PM
09/30/20 09:10 PM
Posts: 31,046 Oregon
AndyF
what are the best spark plugs to use with these heads? The ones that are the correct heat range for the engine.
[Re: duspan]
#2827502
10/01/20 05:38 PM
10/01/20 05:38 PM
tex013
Sydney,Australia
i use NGK BKR6E 11.0:1 98 pump gas . Does not get any race or additive
Tex
[Re: tex013]
#2827598
10/01/20 09:10 PM
10/01/20 09:10 PM
AndyF
Tex Call the NGK tech line and see what they recommend for your engine. I'm pretty sure they'll recommend a 7 heat range rather than the 6 that you are using.
[Re: AndyF]
#2827692
10/02/20 05:23 AM
10/02/20 05:23 AM
tex013
Sydney,Australia
Andy , Not sure there is a ngk help line down here .as a daily driver the -6 is fine especially with biggish cam and 4500 carb . Dont forget we dont get oxygenated fuel here . Our octane probably equeals your 95/96 ? I actually talked to ICE ignition here a few years ago and they recommended a -6 . I have not had pinging or any sign of preignition . No matter weather or engine temp , long highway or city driving . Its a bit like beer , got to try it to see if you like it
Tex
