WIPER/WIPER MOTOR RELOCATION #2822285
09/18/20 02:49 PM
09/18/20 02:49 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
I picked up a gasser project a few years ago and want to make it more of a street gasser than full race car. Prior owner spent many hours redoing the firewall in order to slip in a BB. and push it back a bit past the firewalls original location. What's out there to allow me to install wipers and a wiper motor? Everything is gone from the factory brackets and mounting points. Thanks
Re: WIPER/WIPER MOTOR RELOCATION [Re: A/MP] #2822446
09/18/20 10:30 PM
09/18/20 10:30 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Re: WIPER/WIPER MOTOR RELOCATION [Re: Twostick] #2822454
09/18/20 11:34 PM
09/18/20 11:34 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Yep, like he said. If we knew what the older gasser was, we may be more helpful, I'm not into guessing games on the subject vehicle. Lots of old Mopars don't have much aftermarket support, there isn't much if you don't have the wiper pivots. Gene
Re: WIPER/WIPER MOTOR RELOCATION [Re: poorboy] #2822663
09/19/20 04:50 PM
09/19/20 04:50 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
65 DART.
Re: WIPER/WIPER MOTOR RELOCATION [Re: A/MP] #2824775
09/24/20 10:11 PM
09/24/20 10:11 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Originally Posted by A/MP
65 DART.
Is the sheet metal that originally supported the wiper still present? If you found an original system, does enough of the car still exist that you could still put an original system back into the car? You may still be able to source out original parts, if it would still work in the car.
If everything is gone, you might be farther ahead to install an aftermarket system. Newport Engineering makes an awesome after market wiper system, they may have a full kit for your car. Not cheap, but they work. Gene
Re: WIPER/WIPER MOTOR RELOCATION [Re: poorboy] #2825089
09/25/20 06:18 PM
09/25/20 06:18 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
It was all removed. I saw some pics of street cars/hot rods that had flat/smooth firewalls. Figured they had some trick.
Re: WIPER/WIPER MOTOR RELOCATION [Re: A/MP] #2826094
09/28/20 03:24 PM
09/28/20 03:24 PM
S.E. South Dakota !
bigdad Online content
Still Posting A Lot
bigdad  Online Content
Still Posting A Lot
S.E. South Dakota !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: WIPER/WIPER MOTOR RELOCATION [Re: bigdad] #2826208
09/28/20 06:56 PM
09/28/20 06:56 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Originally Posted by bigdad
I don't see any listings for pivots. the kits here are designed to work with the existing setups, as in replacing a vacuum motor or a v motor with a 12v motor.
Re: WIPER/WIPER MOTOR RELOCATION [Re: Sniper] #2826249
09/28/20 08:20 PM
09/28/20 08:20 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
They have complete systems, with pivots, linkage, motors, switches, wiper blades w/ arms, and motors, but I think you need to call them. I know I've seen 40s GM kits with everything.
Since you don't have anything, I suspect you can use any kit they have that will position the wiper blade where they will clear the windshield in front of you.
Just another thought, lots of the modern Mopars have the entire wiper system in a plastic tray that needs to be removed to access the motor, maybe one of those set ups can be made to work in your car. Think Dodge Intrepid, and Mopar mini vans, to start with. Gene
Re: WIPER/WIPER MOTOR RELOCATION [Re: poorboy] #2826434
09/29/20 12:25 PM
09/29/20 12:25 PM
moparx Offline
moparx  Offline
i have a couple of 99-02 minivan wiper trays here i can take pictures and supply measurements if needed.
beer
