PT Cruiser Turbo intermittent starting problem #2825878
09/28/20 12:29 AM
09/28/20 12:29 AM
Chicago, Illinois
Devil Offline OP
Devil  Offline OP
Chicago, Illinois
So a friend of mine has this PT Cruiser GT Turbo sitting in the back of his barn I'm thinking about picking up. It's low miles, but it has a problem. It will randomly not start. Doesn't matter hot or cold. He has done all the standard stuff to it, starter, fuel pump, ignition, etc.... Even replaced the PCM twice, same issue.
I've heard this is an issue with them, but I can't seem to find the cause and/or fix to this issue.
Has anyone experienced this in the past or heard of a solution?
Thank you,
Ryan
Re: PT Cruiser Turbo intermittent starting problem [Re: Devil] #2826027
09/28/20 01:19 PM
09/28/20 01:19 PM
moparx Online content
moparx  Online Content
with all the items replaced, when it won't "start", does that mean it won't turn over, or it spins over and won't run ?
a lot of territory to cover with what is described.
beer
Re: PT Cruiser Turbo intermittent starting problem [Re: Devil] #2826033
09/28/20 01:29 PM
09/28/20 01:29 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Googled "PT Cruiser intermittent starting" and a number of threads came up.
The PT forum seemed the most specific & knowledgeable.
Neutral switch (AT) and ign switch actuator were mentioned.
Equivalent of a NSS on a stick would be at the clutch pedal, I would think, like my Breeze.
Another site mentioned the cam sensor.
If the car will offer up any trouble codes, that might help.
Re: PT Cruiser Turbo intermittent starting problem [Re: topside] #2826041
09/28/20 01:49 PM
09/28/20 01:49 PM
Chicago, Illinois
Devil Offline OP
Devil  Offline OP
Chicago, Illinois
That's all I got from the owner.
And yeah, the list of things you mentioned is about the same I came up with. So many possible solutions for the problem unfortunately! And all those threads were years old. I was hoping someone in that world might know a more common solution to the issue.
