RB valley cover plate? #2825173
09/25/20 10:11 PM
09/25/20 10:11 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
Does anyone offer a valley plate/cover for a RB with Edelbrock RPM heads that is similar to Indys that has a removeable center plate? (to access lifters & push rods w/ the heads still on)
Thanks, Brian
Re: RB valley cover plate? [Re: '72CudaRacer] #2825184
09/25/20 10:44 PM
09/25/20 10:44 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Check with Andy to see if his plate will work.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: RB valley cover plate? [Re: '72CudaRacer] #2825197
09/26/20 12:39 AM
09/26/20 12:39 AM
AndyF Offline
AndyF  Offline
RPM heads don't overlap the valley plate so a solid plate works just fine.
Re: RB valley cover plate? [Re: AndyF] #2825514
09/27/20 01:00 AM
09/27/20 01:00 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Trickflow do a plate lkke you want .
I used it with 440 source heads BUT used Andys batwing side plates .
Have it now with TFlow 270 heads , no side plates needed
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
