Re: RB valley cover plate?
[Re: '72CudaRacer]
#2825184
09/25/20 10:44 PM
09/25/20 10:44 PM
Posts: 20,179 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Check with Andy to see if his plate will work.
[Re: AndyF]
#2825514
09/27/20 01:00 AM
09/27/20 01:00 AM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
Trickflow do a plate lkke you want . I used it with 440 source heads BUT used Andys batwing side plates . Have it now with TFlow 270 heads , no side plates needed
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
