leaking master cylinder out of cap #282510
04/09/09 01:24 PM
04/09/09 01:24 PM
Anonymous OP
Anonymous OP
I installed a new master cylinder and booster on my dart. Im noticing after I get done driving it that the master is pushing brake fluid out of the cap? I also have a pretty low pedal with good wheel cylinders and calipers as well as no air in the system. Anyone got any ideas what the problem is
Re: leaking master cylinder out of cap #282511
04/09/09 02:36 PM
04/09/09 02:36 PM
Maryland, USA,
satgtx Offline
satgtx  Offline
Maryland, USA,
new MC is bad. had it happen to me went through everything twice until i figured it out. remans suck.
Re: leaking master cylinder out of cap #282512
04/09/09 03:55 PM
04/09/09 03:55 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
check to make sure rubber seal is good on MC, did you bench bleed the MC before putting it on, are rear brakes adjusted up. Could also have possible brake hose bad, if not I agree with above statement MC bad
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: leaking master cylinder out of cap #282513
04/09/09 05:04 PM
04/09/09 05:04 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
What kind of master is and and where did you get it ?
Re: leaking master cylinder out of cap [Re: JohnRR] #282514
04/09/09 05:23 PM
04/09/09 05:23 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
It wouldn't happen to be one of those new style aluminum ones would it?
Maybe from Rick E?
Re: leaking master cylinder out of cap [Re: KillerBee] #282515
04/09/09 06:26 PM
04/09/09 06:26 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
I just went thru this with a new MC. I suspected that the lid itself was leaking due to sloshing, up and downhills, etc. What I did was to lower the level of the fluid slightly (1/2") and put a bit more bend in the cheesy wire bail for more down pressure on the cap. So far, so good.
Re: leaking master cylinder out of cap [Re: Classof70Chally] #282516
04/09/09 09:23 PM
04/09/09 09:23 PM
Race City USA Mooresville N.C...
Ts road runner Offline
mopar addict
mopar addict
Bend the wire down it works
SOUTHERN BORN-SOUTHERN BREED-SOUTHERN DEAD
Re: leaking master cylinder out of cap [Re: Ts road runner] #282517
04/09/09 09:28 PM
04/09/09 09:28 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: leaking master cylinder out of cap [Re: TJP] #282518
04/09/09 10:03 PM
04/09/09 10:03 PM
Cleveland,Ohio
CtownChris Offline
CtownChris  Offline
Cleveland,Ohio
Like they said. Tighten the wire bail. Just squeeze it a little snap it over the cap. Don't take it off the master. Just gently tighten up and replace cap.
"Always go forward: Never go straight"
Re: leaking master cylinder out of cap [Re: CtownChris] #282519
04/09/09 11:18 PM
04/09/09 11:18 PM
Anonymous OP
Anonymous OP
Remember he said a low pedal too. On top of the cap not being secured completely check for an internal leak in the master cylinder. Either that or if it has a brake booster make sure the rod isnt too far in or out.
Re: leaking master cylinder out of cap #282520
04/09/09 11:24 PM
04/09/09 11:24 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Common failure mode, esp. on rebuilts: Pumps fluid from one reservoir to the other. Scary.
Rick
Re: leaking master cylinder out of cap [Re: Rick_Ehrenberg] #282521
04/09/09 11:25 PM
04/09/09 11:25 PM
USA
Rollin Hand Offline
Rollin Hand  Offline
USA
Rick
Re: leaking master cylinder out of cap [Re: Rollin Hand] #282522
04/10/09 12:04 AM
04/10/09 12:04 AM
Montana
P
Posest Offline
Posest  Offline
P
Montana
Had that happen to me also.
