leaking master cylinder out of cap
#282510
04/09/09 01:24 PM
04/09/09 01:24 PM
I installed a new master cylinder and booster on my dart. Im noticing after I get done driving it that the master is pushing brake fluid out of the cap? I also have a pretty low pedal with good wheel cylinders and calipers as well as no air in the system. Anyone got any ideas what the problem is
Re: leaking master cylinder out of cap
#282512
04/09/09 03:55 PM
04/09/09 03:55 PM
Posts: 2,034 NW Indiana
deansrr
NW Indiana
check to make sure rubber seal is good on MC, did you bench bleed the MC before putting it on, are rear brakes adjusted up. Could also have possible brake hose bad, if not I agree with above statement MC bad
1973 Road Runner
1974 Satellite (for sale)
1973 240z (wifes)
1993 Ramcharger (thanks Devil)
2002 Honda S2000
[Re: JohnRR]
#282514
04/09/09 05:23 PM
04/09/09 05:23 PM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
What kind of master is and and where did you get it ?
It wouldn't happen to be one of those new style aluminum ones would it? Maybe from Rick E?
[Re: Ts road runner]
#282517
04/09/09 09:28 PM
04/09/09 09:28 PM
Posts: 15,377 Omaha Ne
TJP
Omaha Ne
Bend the wire down it works
[Re: TJP]
#282518
04/09/09 10:03 PM
04/09/09 10:03 PM
Posts: 412 Cleveland,Ohio
CtownChris
Cleveland,Ohio
Like they said. Tighten the wire bail. Just squeeze it a little snap it over the cap. Don't take it off the master. Just gently tighten up and replace cap.
"Always go forward: Never go straight"
[Re: CtownChris]
#282519
04/09/09 11:18 PM
04/09/09 11:18 PM
Remember he said a low pedal too. On top of the cap not being secured completely check for an internal leak in the master cylinder. Either that or if it has a brake booster make sure the rod isnt too far in or out.
[Re: Rick_Ehrenberg]
#282521
04/09/09 11:25 PM
04/09/09 11:25 PM
Posts: 650 USA
Rollin Hand
USA
Common failure mode, esp. on rebuilts: Pumps fluid from one reservoir to the other. Scary.
Rick
