Map light circuit - What is this? #2824163
09/23/20 03:25 PM
09/23/20 03:25 PM
Hudson Valley
conv440 Offline OP
conv440  Offline OP
Hudson Valley
I am rewiring the map light circuit for a friends 68 Dart GT. This canister is part of the circuit it has 3 connectors and appears to have a pair of bi-metal contact points inside, anyone know what this is and how it works?
Re: Map light circuit - What is this? [Re: conv440] #2824180
09/23/20 03:59 PM
09/23/20 03:59 PM
VA
dragon slayer Offline
VA
Part of the light delay circuit. When you open the door and shut it, the light remains on for a time until the circuit opens so you can see key slot.
Re: Map light circuit - What is this? [Re: dragon slayer] #2824209
09/23/20 04:49 PM
09/23/20 04:49 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
For the ignition switch light. Part of the AO1 light group.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Map light circuit - What is this? [Re: conv440] #2824259
09/23/20 07:15 PM
09/23/20 07:15 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
https://www.autozone.com/electrical.../duralast-relay-19390/221840_113137_6396
If you want OEM
Mopar OEM # 2889565 IGNITION LAMP THERMAL RELAY 1968-1996
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Map light circuit - What is this? [Re: bee1971] #2824419
09/24/20 06:32 AM
09/24/20 06:32 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
If you want OEM
Rockauto have it on half of that price. Sure, will add the shipping cost since I think they only have 3 facilities or so, while Advance auto is all around, but still Rockauto shipping prices are REALLY nice. Quite ago Crown brand was even available on $6 rate, while some ppl sells these in $30-50 rate LOL.
Chrysler dealers must still have them too, because they were plenty used up to 90s Mopars ( including Viper ). But I guess on $20 price rate or so.
Re: Map light circuit - What is this? [Re: conv440] #2824420
09/24/20 06:38 AM
09/24/20 06:38 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Originally Posted by conv440
... and how it works?
this flasher gets constant positive source and dome light ( door ground ) negative and is a normally open circtuit to feed whichever light is conected. As soon gets the ground signal it closes circuit by the heat caused begining to feed the lights network while also keeps on heat. Once door ( or dome light circuit ) is turned off the bimetallic will remain the circuit closed until cool down and cut it ( open ), turning off the bulb
