Re: Map light circuit - What is this?
[Re: dragon slayer]
#2824209
09/23/20 04:49 PM
09/23/20 04:49 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Part of the light delay circuit. When you open the door and shut it, the light remains on for a time until the circuit opens so you can see key slot. For the ignition switch light. Part of the AO1 light group.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: bee1971]
#2824419
09/24/20 06:32 AM
09/24/20 06:32 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Rockauto have it on half of that price. Sure, will add the shipping cost since I think they only have 3 facilities or so, while Advance auto is all around, but still Rockauto shipping prices are REALLY nice. Quite ago Crown brand was even available on $6 rate, while some ppl sells these in $30-50 rate LOL. Chrysler dealers must still have them too, because they were plenty used up to 90s Mopars ( including Viper ). But I guess on $20 price rate or so.
[Re: conv440]
#2824420
09/24/20 06:38 AM
09/24/20 06:38 AM
NachoRT74
Valencia, España
this flasher gets constant positive source and dome light ( door ground ) negative and is a normally open circtuit to feed whichever light is conected. As soon gets the ground signal it closes circuit by the heat caused begining to feed the lights network while also keeps on heat. Once door ( or dome light circuit ) is turned off the bimetallic will remain the circuit closed until cool down and cut it ( open ), turning off the bulb
