1/4 Window is loose, how to reattach #282333
04/09/09 10:20 AM
04/09/09 10:20 AM
Hudson Valley
conv440 Offline OP
conv440  Offline OP
Hudson Valley
My quarter window has come loose and can rock front to back. When you roll up the window it pushes forward and contacts the front window. Does anyone know how these are attached to the lift mechanism and how I could reattach it?
I should add it's a 70 challenger.
Re: 1/4 Window is loose, how to reattach [Re: conv440] #282334
04/10/09 12:53 PM
04/10/09 12:53 PM
Hudson Valley
conv440 Offline OP
conv440  Offline OP
Hudson Valley
Anyone?
Re: 1/4 Window is loose, how to reattach [Re: conv440] #282335
04/10/09 01:18 PM
04/10/09 01:18 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Pull the back seat and the trim panel on that side. You will see how the window is attached and ajusted pretty easily.
Re: 1/4 Window is loose, how to reattach [Re: stumpy] #282336
04/13/09 10:09 AM
04/13/09 10:09 AM
Hudson Valley
conv440 Offline OP
conv440  Offline OP
Hudson Valley
The lift mechanism is attached to the frame ok. The problem is that the glass is pulling out from the aluminum frame. I don't know if it can be glued maybe? Hasn't anyone bought replacement glass and had to attach it to the frame?
Re: 1/4 Window is loose, how to reattach [Re: conv440] #282337
04/13/09 11:39 AM
04/13/09 11:39 AM
Minnesota
3twos Offline
3twos  Offline
Minnesota
I am getting ready to work on my cuda quarter windows which are probably similar to the challenger windows. I have a couple extra windows and I was looking at them yesterday and the glass appears to be pinched between the aluminum with a gasket and rivets are used to pinch the glass and gasket. Maybe your rivets have worked loose? If not you could probably use some type of glue like epoxy or even construction adhesive and leave it at that. Do you have the window removed?
Al & Sheila
Re: 1/4 Window is loose, how to reattach [Re: conv440] #282338
04/13/09 01:44 PM
04/13/09 01:44 PM
Minneapolis Area, MN
tbone Offline
super gas
tbone  Offline
super gas
Funny you bring this up at this time. My car was doing the same thing so I just pulled the panel last night and discovered that the bolt holding the track at the top had fallen out. The way the glass is held in seems to be loose/ wobbly (technical terms), but I think that is normal. So in my case the connection of the window to the frame wasn't the issue it was the track connection to the body. Take the panel off and check it out. Let me know if you have any questions and i will certainly share anything I may know.
Trevor
71 Cuda 340 4spd 00 Ram 2500 03 Chrysler T&C
Re: 1/4 Window is loose, how to reattach [Re: 3twos] #282339
04/13/09 02:14 PM
04/13/09 02:14 PM
Hudson Valley
conv440 Offline OP
conv440  Offline OP
Hudson Valley
You got it, the glass is just 'pinched' in place. I'll check to see if the rivets are loose. Maybe construction adhesive would do the trick. The problem is that the glass is loose, not out. It might be hard to get glue up into the grove without completely removing the window from the aluminum frame. I'll pull the interior apart and post some pix soon.
Re: 1/4 Window is loose, how to reattach [Re: conv440] #282340
04/13/09 08:57 PM
04/13/09 08:57 PM
Hudson Valley
conv440 Offline OP
conv440  Offline OP
Hudson Valley
pix
Re: 1/4 Window is loose, how to reattach [Re: conv440] #282341
04/13/09 08:58 PM
04/13/09 08:58 PM
Hudson Valley
conv440 Offline OP
conv440  Offline OP
Hudson Valley
another, you can see how far the glass pulls up from the frame. The rubber gasket is deteriorated but the glass wont pull free.
Re: 1/4 Window is loose, how to reattach [Re: conv440] #282342
04/13/09 10:08 PM
04/13/09 10:08 PM
Minnesota
3twos Offline
3twos  Offline
Minnesota
I drilled the two rivets that hold the vertical stainless piece onto the aluminum piece and punched them out with a nail.Now I can get the glass out. Maybe you can take it to a glass shop and they probably can get the new rubber and you can re-glue it to the glass
Al & Sheila
Re: 1/4 Window is loose, how to reattach [Re: conv440] #282343
04/13/09 10:33 PM
04/13/09 10:33 PM
Minnesota
3twos Offline
3twos  Offline
Minnesota
I think they call that rubber gasket "filler seal"
I was just looking at www.steelerubber.com/mcg
Al & Sheila
Re: 1/4 Window is loose, how to reattach [Re: 3twos] #282344
04/13/09 11:00 PM
04/13/09 11:00 PM
Hudson Valley
conv440 Offline OP
conv440  Offline OP
Hudson Valley
I didn't find that on the Steele website. Send a URL if you have it and thanks for the answers. BTW are you Sheila or Al?
Re: 1/4 Window is loose, how to reattach [Re: conv440] #282345
04/13/09 11:08 PM
04/13/09 11:08 PM
Minnesota
3twos Offline
3twos  Offline
Minnesota
Al & Sheila
Re: 1/4 Window is loose, how to reattach [Re: 3twos] #282346
04/13/09 11:19 PM
04/13/09 11:19 PM
Hudson Valley
conv440 Offline OP
conv440  Offline OP
Hudson Valley
Got it! That's the stuff. If I use that and some adhesive the window should be good as new.
Re: 1/4 Window is loose, how to reattach [Re: conv440] #282347
04/19/09 07:50 PM
04/19/09 07:50 PM
Hudson Valley
conv440 Offline OP
conv440  Offline OP
Hudson Valley
Repair is done and it really came out great. I ordered PN 70-2170-57 Filler Strip from Steele Rubber Products. Here's a picture of the old, worn filler and the new filler strip from Steele.
Re: 1/4 Window is loose, how to reattach [Re: conv440] #282348
04/19/09 07:53 PM
04/19/09 07:53 PM
Hudson Valley
conv440 Offline OP
conv440  Offline OP
Hudson Valley
I cut the new filler to size and then soaked the glass, channel and filler with window cleaner to lubricate it. The glass is a tight fit but I used a large rubber mallet and gently beat it into place. I then cut the filler flush on both sides. That done you just reinstall the two small phillips screws and reinstall the window, Nice!
