Re: Difference between SS and HD springs?
[Re: DPelletier]
#282323
04/09/09 10:56 AM
04/09/09 10:56 AM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Suffice is to say that now my SS springs and hangers have joined all the other parts that are incorrect or didn't work for one reason or another. More "garage art"! Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: whitemtnelf]
#282324
04/09/09 11:00 AM
04/09/09 11:00 AM
Posts: 17,904 S.E. Michigan
ZIPPY
S.E. Michigan
xhd springs are stock replacements, have no arch at all when the car is sitting on all 4 wheels, and they make the car sit as low as they did when new.
ss springs have noticeble arch, require longer front hangers on a B or E body, and (in most cases, depending on part number) make the back of the car sit higher than stock.
For handling, xhd. For launch and handling, xhd with cal tracs. For launch with no traction devices and a slightly higher center of gravity/slightly worse handling (in most cases, depending on part number), SS.
I have 454/455 ss springs on the gtx, they work great
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#282327
04/13/09 11:10 AM
04/13/09 11:10 AM
DPelletier
The part numbers for the springs in my pics are P3690454 and P369045X (which should be P360455 according to http://www.mo-pod.com/pdf/09_Performance_Catalog-120908.pdf ) ..still; looks like they are supposed to be correct for my application. Oh well, the XHD ones have a nice arc to them and put the car in the perfect position. I just hope they are stiff enough to avoid axle wrap with street tires. Dave
1974 'Cuda
