Difference between SS and HD springs? #282317
04/09/09 10:00 AM
04/09/09 10:00 AM
New Hampshire
W
whitemtnelf Offline OP
W
New Hampshire
Hi,
I've searched the board but can't find a discussion on the difference between HD and SS springs. I'd like to know things like spring rates, ride height, which is more applicable for a street/strip car.
Re: Difference between SS and HD springs? [Re: whitemtnelf] #282318
04/09/09 10:03 AM
04/09/09 10:03 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
HD springs will be better in a street car ...
Of course you are leaving out one important tidbit of info ... uuuummm , what car ???
Re: Difference between SS and HD springs? [Re: JohnRR] #282319
04/09/09 10:21 AM
04/09/09 10:21 AM
New Hampshire
W
W
New Hampshire
'71 Charger - 440, 8 3/4 with 3.73 gears
Re: Difference between SS and HD springs? [Re: whitemtnelf] #282320
04/09/09 10:50 AM
04/09/09 10:50 AM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Stock Hemi XHD springs top; SS springs and perches bottom:
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Difference between SS and HD springs? [Re: DPelletier] #282321
04/09/09 10:51 AM
04/09/09 10:51 AM
DPelletier Offline
DPelletier  Offline
Rear of car with stock hemi springs;
Re: Difference between SS and HD springs? [Re: DPelletier] #282322
04/09/09 10:52 AM
04/09/09 10:52 AM
DPelletier Offline
DPelletier  Offline
rear of car with SS springs;
Re: Difference between SS and HD springs? [Re: DPelletier] #282323
04/09/09 10:56 AM
04/09/09 10:56 AM
DPelletier Offline
DPelletier  Offline
Suffice is to say that now my SS springs and hangers have joined all the other parts that are incorrect or didn't work for one reason or another. More "garage art"!
Re: Difference between SS and HD springs? [Re: whitemtnelf] #282324
04/09/09 11:00 AM
04/09/09 11:00 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
xhd springs are stock replacements, have no arch at all when the car is sitting on all 4 wheels, and they make the car sit as low as they did when new.
ss springs have noticeble arch, require longer front hangers on a B or E body, and (in most cases, depending on part number) make the back of the car sit higher than stock.
For handling, xhd. For launch and handling, xhd with cal tracs. For launch with no traction devices and a slightly higher center of gravity/slightly worse handling (in most cases, depending on part number), SS.
I have 454/455 ss springs on the gtx, they work great
Rich H.
Esse Quam Videri
Re: Difference between SS and HD springs? [Re: DPelletier] #282325
04/09/09 11:05 AM
04/09/09 11:05 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Which springs (part number)?
Which front hangers (part number)?
They look like E or A body springs to me/wrong ones for the car
Rich H.
Esse Quam Videri
Re: Difference between SS and HD springs? [Re: ZIPPY] #282326
04/09/09 11:30 AM
04/09/09 11:30 AM
DPelletier Offline
DPelletier  Offline
Well, I wouldn't be surprised, but I posted about this when I first tried them on the car and nobody had any info that would help. I don't have the #'s here, but I'll look again and post them. What I CAN tell you is that I checked them against the Mopar catalogue and the #'s were corrrect for my listing.
Still, they clearly aren't the same as yours. Some other people posted some pics of thiers that didn't look ridiculous like mine.
Re: Difference between SS and HD springs? [Re: ZIPPY] #282327
04/13/09 11:10 AM
04/13/09 11:10 AM
DPelletier Offline
DPelletier  Offline
The part numbers for the springs in my pics are P3690454 and P369045X (which should be P360455 according to http://www.mo-pod.com/pdf/09_Performance_Catalog-120908.pdf )
..still; looks like they are supposed to be correct for my application.
Oh well, the XHD ones have a nice arc to them and put the car in the perfect position. I just hope they are stiff enough to avoid axle wrap with street tires.
