Angled carb spacers #2821419
09/16/20 09:39 AM
09/16/20 09:39 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Having a issue with float level on my t ram carbs. The carbs set sideways and engine has a 3* angle back. I need 3* carb spacers. Anyone know where to find them. 5* is the smallest I can find. Thanks
Re: Angled carb spacers [Re: mopar dave] #2821547
09/16/20 01:51 PM
09/16/20 01:51 PM
New York, USA
Chargerfan68 Offline
New York, USA
If they are not available, i guess only option would be to have a shop angle mill them to your spec. What material are you talking about? Alum?
Re: Angled carb spacers [Re: Chargerfan68] #2821572
09/16/20 02:35 PM
09/16/20 02:35 PM
Mt Morris Michigan
Mt Morris Michigan
Yes and another idea I had was to have the t ram carb pads machines instead. I think that’s what I will do and get some 1/2” phenolic spacers under the carbs. Thanks
Re: Angled carb spacers [Re: mopar dave] #2821619
09/16/20 04:40 PM
09/16/20 04:40 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
Carb wedge plate
example
https://www.summitracing.com/parts/...QlfBspPIcz6mV6UIu5nbeV39SwhoCY4EQAvD_BwE
I'd suggest finding spherical washers
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Angled carb spacers [Re: mopar dave] #2821620
09/16/20 04:43 PM
09/16/20 04:43 PM
NC
440Jim Offline
440Jim  Offline
NC
I like that idea.
If the manifold carb pad is about 7", the 3 degrees is about :
tan (3 deg) = h/7
h = 7 * tan (3 deg) = 0.367"
The machinist could take more off, at same angle, but remember time is money.
Re: Angled carb spacers [Re: mopar dave] #2821652
09/16/20 06:15 PM
09/16/20 06:15 PM
AndyF Offline
AndyF  Offline
Are you going to angle the carb studs too, or run them thru the carb base at an angle?
Re: Angled carb spacers [Re: oldiron] #2821662
09/16/20 06:37 PM
09/16/20 06:37 PM
Mt Morris Michigan
Mt Morris Michigan
Those are the smallest I could find. I need 3*.
Re: Angled carb spacers [Re: AndyF] #2821664
09/16/20 06:39 PM
09/16/20 06:39 PM
Mt Morris Michigan
Mt Morris Michigan
Yes, what ever he needs to do to make them right. BLP told me today that there will be no power found in leveling these carbs thou. May run them as is til end on season.
Re: Angled carb spacers [Re: mopar dave] #2821838
09/17/20 11:05 AM
09/17/20 11:05 AM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
Yes, sorry, I scanned rather than read your message. 5 Degrees was what I tried. I used them on an indy modman with two edelbrock carbs, thinking the engine tilt was affecting my launch. It made no difference. What it did do was help dump raw fuel when slowing down at the end of a run.
Re: Angled carb spacers [Re: oldiron] #2821844
09/17/20 11:37 AM
09/17/20 11:37 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
How are going to compensate when for the acceleration force and wheelie when the fuel all goes to the back sides of the bowls? Is 3 degrees stationary is an issue, I think not.
Doug
Re: Angled carb spacers [Re: dvw] #2821864
09/17/20 12:30 PM
09/17/20 12:30 PM
Mt Morris Michigan
Mt Morris Michigan
This is looking like leveling the engine itself would be best? With the carbs leaned reward the fuel is already to the rearward side, so what would happen on launch? An issue? Not sure. I’m going to raise float levels til it idles fat and lower a tad, one flat from there. I’ll run it for now.
Re: Angled carb spacers [Re: mopar dave] #2821897
09/17/20 01:47 PM
09/17/20 01:47 PM
moparx Offline
moparx  Offline
if you don't also angle the attaching studs like andy said, you will need to obtain some sort of spherical washers so as to not stress the studs and intake/spacer.
beer
Re: Angled carb spacers [Re: moparx] #2821899
09/17/20 01:54 PM
09/17/20 01:54 PM
Mt Morris Michigan
Mt Morris Michigan
Yeah, I have been thinking that . Might just be better to level the engine, but then we get into drive shaft angles.
Re: Angled carb spacers [Re: mopar dave] #2821937
09/17/20 03:15 PM
09/17/20 03:15 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
What difference does it make? None. The fuel moves around in the bowl all the time.
Doug
Re: Angled carb spacers [Re: dvw] #2821952
09/17/20 04:00 PM
09/17/20 04:00 PM
Mt Morris Michigan
Mt Morris Michigan
I think your right. Wasted time. Indy said that was a corrected intake. I’ll have to measure, if it is I’ll just turn it around.
Re: Angled carb spacers [Re: mopar dave] #2821993
09/17/20 05:26 PM
09/17/20 05:26 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Change the mount points on the motor if you have a plate.
Re: Angled carb spacers [Re: dvw] #2821996
09/17/20 05:28 PM
09/17/20 05:28 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Doug
Re: Angled carb spacers [Re: Dragula] #2822002
09/17/20 06:08 PM
09/17/20 06:08 PM
Mt Morris Michigan
Mt Morris Michigan
I use 1 mm (Schumacher) on pass side to keep motor front moving for fore and aft. Otherwise that would be an easy fix. Thanks guys
