Re: Angled carb spacers
[Re: mopar dave]
#2821547
09/16/20 01:51 PM
09/16/20 01:51 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
If they are not available, i guess only option would be to have a shop angle mill them to your spec. What material are you talking about? Alum?
[Re: mopar dave]
#2821620
09/16/20 04:43 PM
09/16/20 04:43 PM
Posts: 16,925 NC
440Jim
NC
Yes and another idea I had was to have the t ram carb pads machines instead. I think that’s what I will do and get some 1/2” phenolic spacers under the carbs. Thanks I like that idea. If the manifold carb pad is about 7", the 3 degrees is about : tan (3 deg) = h/7 h = 7 * tan (3 deg) = 0.367" The machinist could take more off, at same angle, but remember time is money.
[Re: mopar dave]
#2821838
09/17/20 11:05 AM
09/17/20 11:05 AM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
Those are the smallest I could find. I need 3*. Yes, sorry, I scanned rather than read your message. 5 Degrees was what I tried. I used them on an indy modman with two edelbrock carbs, thinking the engine tilt was affecting my launch. It made no difference. What it did do was help dump raw fuel when slowing down at the end of a run.
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: oldiron]
#2821844
09/17/20 11:37 AM
09/17/20 11:37 AM
Posts: 9,835 MI, usa
dvw
MI, usa
How are going to compensate when for the acceleration force and wheelie when the fuel all goes to the back sides of the bowls? Is 3 degrees stationary is an issue, I think not. Doug
