Front disc brakes #2820395
09/13/20 08:41 PM
09/13/20 08:41 PM
olive branch ms
67llite Offline OP
67llite  Offline OP
olive branch ms
Hey guys i'm in need of help, Installed 4 wheel disc brakes on my 69 dart. On the front i did the larger upper ball joint and 74 upper a arm and spindle. Now my front wheels track wider than the rear wheels about half and inch. How do i correct this with the disc brakes setup intact? The disc set up is a jegs or summit setup, I have to check my receipt to be positive!
Re: Front disc brakes [Re: 67llite] #2820406
09/13/20 09:13 PM
09/13/20 09:13 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
A 1/2" wider track on the front wheels then the track on the rear wheels will not cause a problem with the way the Dart performs as long as the tires clear the fenders. Unless the difference really bothers you, I wouldn't change anything, nor would I be concerned. Gene
Re: Front disc brakes [Re: poorboy] #2820407
09/13/20 09:19 PM
09/13/20 09:19 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Later A bodies had a wider front track stock.
Re: Front disc brakes [Re: Sniper] #2820430
09/13/20 10:18 PM
09/13/20 10:18 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
You could put oem a body small bolt pattern disc brakes on it with machined 5 lug mustang rotors to reduce the track width. but you would have to locate all the parts and spend $$$
Re: Front disc brakes [Re: 67llite] #2820441
09/13/20 10:53 PM
09/13/20 10:53 PM
AndyF Offline
AndyF  Offline
A wider front track is a good thing since the car is nose heavy. It might look a little funny but it is actually a very good design practice. If you mostly care about looks then you can use spacers in the rear or buy wider rear wheels or swap in a longer rear axle or all sorts of other solutions.
Re: Front disc brakes [Re: AndyF] #2820581
09/14/20 12:44 PM
09/14/20 12:44 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
The issue with the wider front track is if you lower the car very much you increase the chance that the top of the tire will rub on the fender.
