Indy low deck block distributor #2814488
08/28/20 07:16 PM
08/28/20 07:16 PM
Yakima, WA
K
kevinlc Online content OP
kevinlc  Online Content OP
K
Yakima, WA
Since my 383 msd distributor is 3/4 of an inch too short to engage the oil pump drive I’m assuming
I need a 440 one. Is this correct?
Re: Indy low deck block distributor [Re: kevinlc] #2814493
08/28/20 07:31 PM
08/28/20 07:31 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Yup!!
If it is new I can swap it for you.Todd
Re: Indy low deck block distributor [Re: sasquatch] #2814495
08/28/20 07:48 PM
08/28/20 07:48 PM
Yakima, WA
K
K
Yakima, WA
Wish it was but it’s a few years old. Thanks for the info.
Re: Indy low deck block distributor [Re: kevinlc] #2814578
08/28/20 11:37 PM
08/28/20 11:37 PM
CDoering Offline
CDoering  Offline
You can call MSD and order a low deck or tall deck center shaft. The distributor body is the same, I have swapped them before.
If I remember I had to drill the shaft for the roll pin as it did not come drilled.
Re: Indy low deck block distributor [Re: CDoering] #2817111
09/04/20 08:11 PM
09/04/20 08:11 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
That's some good info. I went and bought a new MSD distributor when I learned that my low deck distributor wouldn't work in Indy's lowdeck frown
Re: Indy low deck block distributor [Re: PolyDart] #2817237
09/05/20 02:14 AM
09/05/20 02:14 AM
Yakima, WA
K
K
Yakima, WA
I called msd and they do not offer replacement shafts.
Re: Indy low deck block distributor [Re: kevinlc] #2817546
09/05/20 06:19 PM
09/05/20 06:19 PM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
I think I have a shaft let me check my stash. I ordered one from them for this very reason. I will look and report back.
Re: Indy low deck block distributor [Re: biff426] #2817550
09/05/20 06:33 PM
09/05/20 06:33 PM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
I have a brand new shaft. I can't remember now if I ordered a tall deck or low deck I am second guessing myself it has been a few years. This shaft measures right at 12 inches. If it will work let me know and its yours.
