Page 1 of 3 1 2 3
Some pics of my ported 15° W2 heads....... #281670
04/08/09 08:14 PM
04/08/09 08:14 PM
SoCal
Brian Hafliger Offline OP
SoCal
Here are some pics of my 15° W2 heads for a 48° lifter bore block.
I'm using an early R1 48° block. Going to be a nice little 360, all iron I guess to be different
Flow #'s to follow.
I think the 15° valve angle would work better if the port was raised more. But they work good enough for what I want out of the engine.
Chamber will be 48cc when finished.
Brian
Re: Some pics of my ported 15° W2 heads....... [Re: Brian Hafliger] #281671
04/08/09 08:15 PM
04/08/09 08:15 PM
SoCal
SoCal
Intake on the head after flowing.
Re: Some pics of my ported 15° W2 heads....... [Re: Brian Hafliger] #281672
04/08/09 08:15 PM
04/08/09 08:15 PM
SoCal
SoCal
One side of chamber:
Re: Some pics of my ported 15° W2 heads....... [Re: Brian Hafliger] #281673
04/08/09 08:16 PM
04/08/09 08:16 PM
SoCal
SoCal
Other side of chamber:
Re: Some pics of my ported 15° W2 heads....... [Re: Brian Hafliger] #281674
04/08/09 08:16 PM
04/08/09 08:16 PM
SoCal
SoCal
Exhaust port:
Re: Some pics of my ported 15° W2 heads....... [Re: Brian Hafliger] #281675
04/08/09 08:17 PM
04/08/09 08:17 PM
SoCal
SoCal
You can see the ex. ports don't need to be huge to flow well:
Re: Some pics of my ported 15° W2 heads....... [Re: Brian Hafliger] #281676
04/08/09 08:17 PM
04/08/09 08:17 PM
SoCal
SoCal
Difference between ported intake port and OOTB:
Re: Some pics of my ported 15° W2 heads....... [Re: Brian Hafliger] #281677
04/08/09 08:22 PM
04/08/09 08:22 PM
SoCal
SoCal
And....flow #'s.
2.08 intake x 1.60 exhaust
28" 4.030 bore
Lift Int. Ex.
200 145 108
300 218 158
400 261 206
500 295 229
600 316 240
700 327 240
Just some pics for fun. I'll post more pics of the build as things get done. Block is done except for drilling the lifter bores.
Crank is balanced, etc....
Think I have my engine sold, so hopefully I'll have this in by the end of summer!
Brian
Brian Hafliger
Re: Some pics of my ported 15° W2 heads....... [Re: Brian Hafliger] #281678
04/08/09 08:33 PM
04/08/09 08:33 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Did you use templates? If so do you have any you could loan me?
Re: Some pics of my ported 15° W2 heads....... [Re: ScottSmith_Harms] #281679
04/08/09 08:38 PM
04/08/09 08:38 PM
SoCal
SoCal
Uh....this goes waaaaay beyond templates...LOL!
Re: Some pics of my ported 15° W2 heads....... [Re: Brian Hafliger] #281680
04/08/09 09:11 PM
04/08/09 09:11 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I should have flowed it on a 4.250 bore
I got it.
Re: Some pics of my ported 15° W2 heads....... [Re: S/ST 3040] #281681
04/08/09 09:18 PM
04/08/09 09:18 PM
eastern Ky
hilbillyconquest Offline
eastern Ky
cool pics brian, i will look forward to see how much power it makes and how fast it runs.
Re: Some pics of my ported 15° W2 heads....... [Re: S/ST 3040] #281682
04/08/09 09:35 PM
04/08/09 09:35 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I got it.
Finally,an inside joke that I get !!!!
Re: Some pics of my ported 15° W2 heads....... [Re: Dunnuck Racing] #281683
04/08/09 11:04 PM
04/08/09 11:04 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Re: Some pics of my ported 15° W2 heads....... [Re: HotRodDave] #281684
04/08/09 11:36 PM
04/08/09 11:36 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Actually I wasn't joking, a buddy of mine bought a set of heads just like yours and is looking for some help in doing a home port job, he's asked me for help (templates) if they exist? At any rate, the 4.25 bore/flow deal went right over my head as well, please enlighten me?
Re: Some pics of my ported 15° W2 heads....... [Re: ScottSmith_Harms] #281685
04/09/09 12:05 AM
04/09/09 12:05 AM
SoCal
SoCal
I figured you were joking, cause template porting won't get you anywhere close to this kind of flow.
Anyhow, if they are the 15° head, I would leave the 2.02 valve for now, and do some chamber work around the valves and a good 4 angle valve job.
Use a nice fat 30° back cut on the intake valve and call it good.
Look at the pics closely, you'll see there is a ton of work in the intake ports that I did.
Plus, alot of sb's will not want this size of port.
You can also slim down the guide boss some...
Brian
Re: Some pics of my ported 15° W2 heads....... [Re: Brian Hafliger] #281686
04/09/09 12:21 AM
04/09/09 12:21 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
That's cool, I'm not a head porter so don't have much of a clue, but to my credit didn't expect to reach those numbers with simple porting templates either Just looking to give my buddy something of a guideline so he doesn't make an expensive mistake. Thanks for the suggestions.
Re: Some pics of my ported 15° W2 heads....... [Re: ScottSmith_Harms] #281687
04/09/09 12:23 AM
04/09/09 12:23 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
I actually have a set of the old w2 templates...
Tony
70 AARCuda Vitamin C
Re: Some pics of my ported 15° W2 heads....... [Re: 70AARcuda] #281688
04/09/09 12:40 AM
04/09/09 12:40 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
looks well......yummy, no wonder you get such good #'s, i look at those ports and i look at my eddys and no wonder im hy heads are lacking
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Some pics of my ported 15° W2 heads....... [Re: 70AARcuda] #281689
04/09/09 12:49 AM
04/09/09 12:49 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Let me take a stab at the 4.25 joke....It's because your heads flow like a decent set of big block heads
*If you do have the templates that would be cool
Page 1 of 3 1 2 3
