Mopar fastener dimensions #2815761
09/01/20 07:56 AM
09/01/20 07:56 AM
Clinton, NJ
N
njmopar Offline OP
njmopar  Offline OP
N
Clinton, NJ
Hello -
Working on a new project for my daughter, a 2001 Jeep XJ Cherokee. Got a great deal on it, considering it is pretty much rust free. It does need paint, which I have blown the thing apart to do it correctly.
I would like to go through and replace many of the fasteners that are cruddy looking on trim, etc. Mopar part numbers are easy to find, but is there any known cross reference guide from a mopar part number to a standard screw size? Would save me having to measure each one and cross reference.
I guess I got spoiled from all the fastener kits for the old cars, you really dont have to think about that, just buy the kit.
Thanks.
Rob
Re: Mopar fastener dimensions [Re: njmopar] #2815940
09/01/20 06:19 PM
09/01/20 06:19 PM
New Jersey
P
Powerflow Offline
Powerflow  Offline
P
New Jersey
In the old (reallly old!) days Section 18 of the parts catalog had fastener specs ans dimensions. Don't know if that is true today.
Re: Mopar fastener dimensions [Re: Powerflow] #2815962
09/01/20 07:37 PM
09/01/20 07:37 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
hi rob , the other thing to think about are most of the fasteners on that 2001 jeep are going to be metric. I don't know of any jeep bolt lits like our old mopars . hope someone knows a company for you . drive ronnie
Re: Mopar fastener dimensions [Re: 1969ronnie] #2815972
09/01/20 07:54 PM
09/01/20 07:54 PM
new berlin wisconsin
Mr T2U Online content
Mr T2U  Online Content
i would suggest downloading the auveco catalog.
https://www.auveco.com/
we order auveco fasteners thru the paint store on a weekly basis at the bodyshop i work at.
perception is 90% of reality
Re: Mopar fastener dimensions [Re: Mr T2U] #2816195
09/02/20 12:03 PM
09/02/20 12:03 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
The cataloging is hit and miss on fasteners. Sometimes they show them as not serviced separately. Sometimes dimensions are listed, sometimes not. What I used to do when I was a parts guy at the dealer was to just go through all of our parts bins/drawers to find something. Was usually successful doing that. You will not find listings at all at parts stores for dimensions, locations, quantities etc for vehicle fasteners. The closest I ever came up with, when working at the stores, was head bolt and wheel stud listings in the Dorman catalog.
Carl Kessel
Re: Mopar fastener dimensions [Re: CKessel] #2816541
09/03/20 07:21 AM
09/03/20 07:21 AM
Clinton, NJ
N
njmopar Offline OP
njmopar  Offline OP
N
Clinton, NJ
Thanks for the input. I guess I will just measure each one and look up on the Mcmaster site. They have just about everything, just a matter of matching up.
Re: Mopar fastener dimensions [Re: njmopar] #2816658
09/03/20 01:09 PM
09/03/20 01:09 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
OE stuff can have special coatings[ for corrosion], flanged heads, pilot tips on the ends, smaller heads, captive washers etc. Generally no reason you can't use generic stuff if thats all you can source. Just watch your hardness ratings and fastener placements. If its around a cooling jacket, maybe go stainless. Same on exhaust.
Carl Kessel
Re: Mopar fastener dimensions [Re: CKessel] #2816960
09/04/20 11:05 AM
09/04/20 11:05 AM
moparx Offline
moparx  Offline
make sure when using stainless you do two things.
1 : make sure to use a good grade from a good company such as ARP
2 : use lots of anti-seize to prevent thread galling.
beer
Re: Mopar fastener dimensions [Re: moparx] #2817013
09/04/20 01:06 PM
09/04/20 01:06 PM
N.J. north west
1972challenger Offline
N.J. north west
Most of the body and chassis fasteners will be metric, common thread pitches too. Order bolts from Mcmaster.com as they have pretty good prices and most sizes will be sold in boxes of 25, 50, 100 etc. S.S. bolts should have a small dab of copper anti seize. Most of the bolts on an XJ areM5x0.7, M6x1.0, M8 x 1.25 and M10 x 1.5. The engine should be SAE for most but accessory mounting not attached to the engine its self will be metric. McMaster also sells killer coated bolts that will hold up well and are graded in 10.8 and 12.8 for suspension and axle attachment.
