Page 2 of 3 1 2 3
Re: Tools for cutting fiberglass. [Re: CMcAllister] #2814046
08/27/20 07:06 PM
08/27/20 07:06 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
A hatchet on fiberglass! .... up
Did that a BUNCH of times for our Canuckada fiends !!
Back then STILL DO ... the Canuckada customs would STICK IT to them big time ...
But a damaged part PURPOSELY DAMAGED in the scoop area was cheap to go through customs!
A 200$ hood is now a 40$ piece !
I had a HATCHET at the shop just for that !
Re: Tools for cutting fiberglass. [Re: dOc !] #2814106
08/27/20 09:56 PM
08/27/20 09:56 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
I think I could cut a more straight line with a 3” angle grinder. Thanks for the tips guys.
Re: Tools for cutting fiberglass. [Re: CMcAllister] #2814147
08/27/20 11:09 PM
08/27/20 11:09 PM
Mt Morris Michigan
Mt Morris Michigan
looking at this tool to get the straightest lines. Everything will be marked out and taped to get a good job.
Re: Tools for cutting fiberglass. [Re: jcc] #2814246
08/28/20 10:10 AM
08/28/20 10:10 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Done plent of fiberglass and carbon. Cut off wheel to get the basic shape and drum sander wheel for the fine tuning. Pretty easy material to work with honestly.
Re: Tools for cutting fiberglass. [Re: CMcAllister] #2814263
08/28/20 11:01 AM
08/28/20 11:01 AM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Originally Posted by CMcAllister
Originally Posted by Doc Fiberglass
Originally Posted by JERICOGTX
Originally Posted by Bad340fish
I used a Jigsaw on mine. The dust wasn't bad at all.
Jigsaw works the best. Leave a little wiggle room, and finish off with a flap wheel on the grinder. I'll be working on my hood tonight...
A variable speed saber saw on sloooower speed...,
FG dust ? .... whata buncha wimps !
larryLOVEit and I luv the smell of that dust in the morning..... smoke
It tastes like VICTORY!
I hear it causes brain damage after a while. And drooling.
You omitted one last common symptom , "rabid denial" laugh2
Re: Tools for cutting fiberglass. [Re: Al_Alguire] #2814457
08/28/20 05:07 PM
08/28/20 05:07 PM
Mt Morris Michigan
Mt Morris Michigan
Thanks. The hood arrived today and looks like a very nice piece. Looks like i will have to cut into some of the bracing near the rear of the hood. Was hoping i would not have to and because of that i may have to take it to a marine or boat shop to have it finished. Will see. The hood is designed for cutting as there is no bracing in the center, but the T ram pokes up thru at the rear of the hood. Looking like about 4" from the rear.
Re: Tools for cutting fiberglass. [Re: mopar dave] #2814470
08/28/20 05:55 PM
08/28/20 05:55 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I made a plug to go inside the bracing and then glassed over it.Not hard to do.
Re: Tools for cutting fiberglass. [Re: Clanton] #2814472
08/28/20 06:05 PM
08/28/20 06:05 PM
Mt Morris Michigan
Mt Morris Michigan
I have never worked with fiberglass patch. Is it hard to work with?
Re: Tools for cutting fiberglass. [Re: mopar dave] #2814484
08/28/20 07:02 PM
08/28/20 07:02 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I put 6 to 8 layers of glass cloth.Work out any bubbles between layers.You can mix small amounts and I made it with more than required hardener.A cheep brush and plastic scraper.
Re: Tools for cutting fiberglass. [Re: Clanton] #2814507
08/28/20 08:32 PM
08/28/20 08:32 PM
Mt Morris Michigan
Mt Morris Michigan
Is there a kit available with everything I need?
Re: Tools for cutting fiberglass. [Re: mopar dave] #2814546
08/28/20 09:41 PM
08/28/20 09:41 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
If the auto parts store is any good by you they should have it all but not 1 package.
Re: Tools for cutting fiberglass. [Re: Clanton] #2814562
08/28/20 10:13 PM
08/28/20 10:13 PM
Mt Morris Michigan
Mt Morris Michigan
Ok, thanks. ill see how it goes.
Re: Tools for cutting fiberglass. [Re: mopar dave] #2814605
08/29/20 06:00 AM
08/29/20 06:00 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
3" metal cutting disc and a hole saw for the corners for the rough work. Straightened up with hand files and wet / dry for finishing. I had to glass on a support strut underneath on either side of the hole. With so much cut out it lost some rigidity and would likely have cracked the paint. I used a shop vac to cut down on the dust and wore a one piece disposable paper suit with my paint respirator / mask on too. (hood is still at the painters)
Re: Tools for cutting fiberglass. [Re: Tig] #2814646
08/29/20 10:04 AM
08/29/20 10:04 AM
Mt Morris Michigan
Mt Morris Michigan
Nice job. Mine is a bolt on hood. The hood is designed for hole cutting, so hope i wont have to add any supports.
Re: Tools for cutting fiberglass. [Re: mopar dave] #2814954
08/29/20 11:02 PM
08/29/20 11:02 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Not really, once you get the hang of it. Be warned, its all about time, temp, mixing ratio, and material thickness.
Best to practice a layup on a test piece to get your skills up to speed first if you want to minimize your post layup trim, finish work, etc and keep your hood nice and not distorted, in that FG can warp adjoining surfaces upon curing.
Re: Tools for cutting fiberglass. [Re: jcc] #2815087
08/30/20 12:38 PM
08/30/20 12:38 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Damn ccj ... you sound VERY WELL VERSED...
I coulda used a apimp like you some years back ....
But da BOSS would have hammer yur azz over yer politics tsk grin
Re: Tools for cutting fiberglass. [Re: jcc] #2815246
08/30/20 09:22 PM
08/30/20 09:22 PM
Mt Morris Michigan
Mt Morris Michigan
Its all cut, just need to finish out sanding. I used a die grinder with a 3" wheel and a 1/2" drill bit for the corners. Where i cut thru the hollow brace i'm thinking maybe tiger hair or Duraglass to fill and sand out instead of fiberglassing, which i know nothing about.
Re: Tools for cutting fiberglass. [Re: mopar dave] #2815252
08/30/20 09:39 PM
08/30/20 09:39 PM
Mt Morris Michigan
Mt Morris Michigan
Pic
Re: Tools for cutting fiberglass. [Re: mopar dave] #2815253
08/30/20 09:40 PM
08/30/20 09:40 PM
Mt Morris Michigan
Mt Morris Michigan
Used a DA to straighten my cuts.
Re: Tools for cutting fiberglass. [Re: mopar dave] #2815254
08/30/20 09:41 PM
08/30/20 09:41 PM
Mt Morris Michigan
Mt Morris Michigan
the pics are from my phone, sorry there sideways.
Page 2 of 3 1 2 3
